which gear oil to use and why??
Old 09-24-2008, 10:13 AM
$O$OE's Avatar
Default which gear oil to use and why??
The current gear oil that is in my rear diff is:
http://www.castrol.com/castrol/secti...tentId=7036192
and to me it seems like it makes more noise than before we changed it. We did not add the GM lim. slip adhsve. It was added 2days after the oil was put in. Can that be the cause of all the noise from the oil being added 2 days later?
and the oil im planning to add new oil to see if the noise reduces, but will add the GM lim slip oil first before i add the gear oil, the new oil im gonna add next is:
http://royalpurple.com/gear-oil.html
Old 09-24-2008, 10:57 AM
$O$OE's Avatar
any1?
Old 09-24-2008, 11:10 AM
FearTheDeer's Avatar
You should state what your car is. Cuz im pretty sure LS1/LT1's have different LSD's.
When i was at SoCal speed in Santa Ana. Mike was putting Redline 75W90 in his LS1 Trans Am. Id go with that.
Old 09-24-2008, 11:15 AM
99Hugger's Avatar
Just a note when you change to the Royal Purple, you dont need the GM Oil.
Old 09-24-2008, 11:33 AM
$O$OE's Avatar
its an lt1..i know some say i dont need it cuz the oil comes with the LS, but i was told to still put it in..
Old 09-24-2008, 12:37 PM
crossroads's Avatar
i did the additive w/ royal purple, but i still have noise(bearings) so i'll just drive it till she blows and get a 9"
the 10 bolt really is crap, whats it sound like it could be your bearings?
Old 09-24-2008, 12:54 PM
$O$OE's Avatar
i cant take a risk right now on my car messing up, im trying to get everything on it going good since i need to drivve it to dallas next week..just changed the outer tie rods last night, all the oils in the car, hoses, new brakes with rotors, and all i need is this fucken problem with the noise in my diff
Old 09-24-2008, 01:18 PM
alamantia's Avatar
LT1's came with auburn units, auburn units dont work in synthetic, they work in regular mineral oil with the additive.
Old 09-25-2008, 09:12 AM
nj02vette's Avatar
Yep,
All LT1's came with auburns. What that means is they use a clutch pack in the diff. You shouldn't use synthetic, and absolutely must use the LSD additive. 98 LS1's also cam wih auburns. 99+ (I believe) came with Torsens, and technically don't need the friction modifier, but I add it anyway.
