Gen 5 Camaro Drivetrain Tech Clutch, torque converter, rear end, axles
6L80 to Turbo 400 swap....... almost complete.
Old 08-11-2010, 07:51 PM
Fast 2010's Avatar
Default 6L80 to Turbo 400 swap....... almost complete.
Posted a while back on this. Trans is in.... converter built... driveshaft cut and re- balanced.... Hurst quarter stick in. That was the easy part. As far as the electronics went, i had to pull the TCM out of the factory trans and mount it external plugged in. Could not fool the system any other way. Everything works on the GM lan data system and windows.. radio.. heater... cluster... all were inop with it unplugged. So far so good. Gonna have the tuning done soon and hope for the best. Thought id share and hopefully make your project simpler than mine was.
Old 08-11-2010, 11:07 PM
someday's Avatar
y would u change the trans? whats wrong with having a 6 speed??
Old 08-12-2010, 04:24 PM
MASS seller approved
smok'nZ's Avatar
probally wants more of a drag car, also having that 6spd build would probally cost at least double what a th400 built for 1000hp would cost
Old 08-12-2010, 10:56 PM
Fast 2010's Avatar
Exactly. Cheaper to build and a lot of experience out there with the TH 400... rather than only a handfull of people that can build the 6L80 to hold up as good. Got about 400 miles on the install . Happy with it so far. Lost some low end but that was expected... thinking the 410 gear could solve that.
Old 08-13-2010, 01:05 PM
smok'nZ's Avatar
ya i went from a fast 90/90 and 3.23 gear to a fast 102/102 4.10 and it woke it up for sure and mine was only a big cam only ls1 not a bad *** 6.2 or whatever you got
Old 08-13-2010, 09:36 PM
Fast 2010's Avatar
Waiting on the tune.... been spraying it with a 150 shot. Gonna come up to a 175 after the tune. Going to a plate system also. Hoping for some low 11's without the gear. anxious to see the outcome.
Old 08-13-2010, 09:43 PM
jay_lt4's Avatar
all you had to do was jump the can lines, pin 10 to 14 and 11 to 13 to complete the can data circuit:
Attached Thumbnails 6L80 to Turbo 400 swap....... almost complete.-6l80e-data-lines.gif
Old 08-14-2010, 08:48 AM
Fast 2010's Avatar
Tried that. Then i ran into problems with the PRNDL. Need park or neutral to start... then need drive for the tune to work... otherwise it would hit the limiter at 5000 RPM instead of the programed 6900 RPM and would run in a limp mode... lower power.. acted like the timing was off. So far moving the PRNDL by hand into drive works till i find a better idea. ????????
Old 08-15-2010, 02:48 PM
jay_lt4's Avatar
jump the can lines and program your ecm with a ls3 file, then turn off all the starter enable checks in the tune
Old 08-16-2010, 06:51 PM
LS1Tech Sponsor
Robin L's Avatar
I went with the 4L80E in mine. Also since it was a Stick car I didn't have a lot of problems with the tune or ECU. Also I used a 2.75 first gear and the stock 3.45 rear gear.
So far my best 60' on radials has been a 1.56.
Robin
Old 09-16-2010, 03:51 PM
robertbartsch's Avatar
I used to rebuild TH400 trans in the late 1970s.... basically bullet proof 3-speed that can handle tons of power...
Old 11-27-2010, 01:25 PM
LS1TECH Sponsor
Ryne @ CMS's Avatar
why not just load a Manual ls3 camaro operating system?
Old 11-27-2010, 03:21 PM
jay_lt4's Avatar
you would still need to jump the can data lines at the tcm connector to complete the data circuit
Old 11-27-2010, 04:30 PM
LS1TECH Sponsor
Ryne @ CMS's Avatar
thats fine, but at least that way you wouldnt have the PCM looking for the TCM
Old 12-01-2010, 05:02 AM
xx_ED_xx's Avatar
Do you have gm global connect access?
edward.coss@gmail.com
Old 12-01-2010, 06:47 AM
jay_lt4's Avatar
yes i do
Old 12-01-2010, 05:45 PM
HioSSilver's Avatar
....uuuhh wow....You guys sure know how to take a modern hotrod and step it back inn time 40 years.
Old 12-01-2010, 10:24 PM
Wild85's Avatar
Do we have an update on this car? How is it functioning? What was done in the ecu to allow for the car to start up etc. How about a speed signal to the speedometer, is the speedo working or no? I have a turbo400 in my G8 right now, but we havent dug into the getting the car to run yet. So any tips would be great.
Old 12-01-2010, 11:15 PM
69TA's Avatar
you must have crazy room in the tunnel
with that big *** tranny gone now.
now if only we can get your 6 speed auto
to work with out all the computer stuff.
Old 12-02-2010, 04:07 PM
Wild85's Avatar
That tranny weighs around 220 lbs. the turbo400 is like 120 with all of the lightened internals.
Quick Reply: 6L80 to Turbo 400 swap....... almost complete.
