Oil cooler on TR6060?
Hey guys, so I'm installing an lq4/afr heads w/ tr6060 on my rx7.
I heard that there is an oil cooler for the transmission on the tr6060. I have the trans, but I don't see any oil lines. I'm looking to do a delete on the oil cooler. I was wondering if you guys can help me out and if anyone know of some sort of kit or plugs to use to delete the lines.
Also, I don't see any oil lines that go into the transmission. Can you guys guide me or show me some pictures of the locations for these things, because I'm currently baffled.
I attached some pics of my transmission so you guys have a better idea of what I'm currently working with.
Thank you all in advance!
The TR6060 uses automatic transmission fluid, not oil. There is no factory oil cooler on it or any cooler at all mounted directly to it. There are lines that run from it to the radiator and back. That is the cooler.
The two lines going past the front of the transmission in the picture are the lines that run to the bottom of a Gen V camaro radiator. I believe one of them runs under the transmission to the other side.
The following users liked this post:
Homer_Simpson (09-22-2023)
Either way, do you know whats the best way to delete those lines or maybe loop them? This is going on an rx7, so my radiator wont be plunged for the lines.
Thanks!
