Old 05-18-2016, 12:46 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Specifications & General Maintenance
Print Wikipost
Weight Reduction
Old 01-29-2010, 07:34 AM
unb
unb's Avatar
Default Weight Reduction
What can be done to reduce the weight of the 2010 Camaro 2SS? It's a hefty beast, which is ok for the most part, but I was wondering what it would be like if it were a couple hundred lbs leaner. I was thinking
1. remove the back seats. Can this be done in a clean way--without leaving a gaping mess behind?
2. replace the axle with a carbon fibre axle. I am unsure how many lbs less this would be.
3. replace the hood with a carbon fibre hood. I don't know if this is an option--I haven't seen any cf hoods for the 2010 yet.
4. replace the doors??
I am reaching here. Any references you can point me to, or methods you have used?
Thanks!
Old 01-29-2010, 08:07 AM
IZRED's Avatar
I don't know if these are things you would want to do, but I'll throw it out there. Aftermarket seats, smaller rims if the brakes allow it, aftermarket stereo and take out all the speakers except two, take out the windshield washer accessory, take out the spare {I don't know if they come with one}, take out the insulation under the hood and doors, take off the engine cover, headers and aftermarket exhaust, lightweight pulleys, take out the AC accessory, take out the window motors. All of that is a good amount of weight without really stripping it.
Old 01-29-2010, 08:12 AM
OrangeChevyII's Avatar
You just destroyed a 40,000 dollar car.
Old 01-29-2010, 08:22 AM
IZRED's Avatar
I don't think any of that would matter to him. He's willing take out the back seats.
Old 01-29-2010, 10:52 AM
PowerPro01's Avatar
50-60 lbs. can be shaved with lite weight forged wheels. More, if you go to 18-19" wheels/tires...
"True" carbon fiber body panels (hood/fenders/trunk lid/spoiler) would get you to 100+, in total. c/f doors without side beams and lexan glass would shave a bunch more.
200 is not all that difficult, but you'll not have nearly as many creature comforts as you do now...
Old 01-29-2010, 03:47 PM
ecmoman's Avatar
If you're gonna gut it, why spend the extra for the 2SS?
Old 01-29-2010, 09:43 PM
11SECSS's Avatar
No different then back in 1998-02 when we where doing it to a 30k dollar car.
Old 01-29-2010, 10:00 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,222 Likes on 779 Posts
LS1Tech 10 Year
Easiest way to remove 400 lbs would be to get a C6.
Old 01-30-2010, 02:56 AM
TierAngst's Avatar
Didn't realize a C6 weighed so much!
Old 01-30-2010, 07:58 AM
Dark SS's Avatar
Ditch the IRS
Old 01-30-2010, 08:39 AM
SLOW SEDAN's Avatar
Its pretty easy to take weight off the Zeta platform and not look too stripped. I've been able to take off roughly 300lbs without too much effort.
Start with removing the engine covers and misc plastic. -5lbs
Replace battery with lighter version. -20lbs
Replace full OEM exhaust with longtubes, xpipe, and lighter mufflers. -73lbs (30 headers, 24 mufflers, 19 mid pipe)
Back seat as already stated. Bottom doesn't weight much but the back has a few lbs in it. -15
There is a few lbs in the child seat retention system underneath the rear seats. -5lbs.
Lighter wheels as already stated. Could be up to 100lbs depending on how drastic you go.
OnStar box an battery. -5lbs
Trunk Liner. -3lbs
Remove factory speakers and replace with good speakers up front. -10lbs
Hoodliner. - 3lbs
Factory airbox. Replace with aftermarket. -4lbs
Foam block and airpump in trunk. -7lbs
Drain windshield washer tank.
Run a half tank or less of fuel.
Remove floor mats.
Sound deadening under carpet... similar to the old light weight carpet once removed. -10lbs
Mid tunnel brace. -3
Rear subframe weights if you have them. -7lbs
Driver/Passenger seats are heavy 50-60lbs each. Easily replaced with race seats.
I was able to drop from a race weight of 4,000lbs down to the 3,6xx range without replacing the seats just all the little things that add up.
Old 02-01-2010, 05:19 PM
Formula51's Avatar
The weight of the exhaust and wheels leads me to believe that GM has some weight savings potential from the factory if they so choose. Perhaps they will use this avenue to keep the weight down on the Z28....
Old 02-01-2010, 06:57 PM
Luckymex_dallas's Avatar
remove the AC compressor. lines. control arms. go tubular.
take out window regulators
change out glass to lexan
take the motors out of front seats.
suspension bolt ins!
Old 02-03-2010, 05:11 PM
LS1LT1's Avatar
Lightbulb
While I see your point and am not sure if it truly matters to him or not, I personally don't put 'back seat removal' in the same category with 'AC and/or power window motor removal', but that's just me.
I've pulled the seats (mere bolts) out of my LS1 Z28 but never once even considered pulling the AC (draining refrigerant, disconnecting multiple lines/tubes, wiring etc.).
Start with a zero option 1SS (as I would) if you're truly concerned about weight.
Old 02-12-2010, 02:05 PM
8ty8 LS1's Avatar
lol that's what i tried telling steph, marc. she wasn't having any of it...she "needs" a sunroof and everything else hahaha
Old 02-12-2010, 11:19 PM
LS1LT1's Avatar
Talking
Yeah LOL, I know she also wanted those center console gauges (I really like them as well) and I think the only way to get them (at the time at least) was to go with the 2SS.
Old 02-13-2010, 11:57 AM
g-townmach's Avatar
Iforged has their new "Race Series" wheels available in awesome looking profiles. They are supposed to be super light but super strong. Wheels would definitely cut down on weight.
Also, there's a few companies that will be coming out with solid axle conversions for the 2010 Camaro sometime soon. Would save ALOT of weight and be more durable. Keep your eyes peeled for them.
Putting on an aftermarket exhaust will shed a bunch of weight too. Those freakin "gas-tank" looking mufflers are huge and weigh alot. I think you can shed like 40-50 lbs by ditching them.
Tubular K-members and control arms as well as aftermarket trailing arms, toe arms, etc will save you weight. Check out spohn or bmr.
Then you can save a little here and there with small things... Back seat, etc
Old 02-13-2010, 07:49 PM
GIZMO's Avatar
I am slowly getting weight out of my 2010. I should have all the seam sealer and sound deadener finished tomorrow. I will post the weight when I get done.
Old 02-13-2010, 08:19 PM
I just can bring myself to start tearing out all the parts, I like my car with no squeeks or funny noises. I've thoughth about selling it and buying the body in white and getting serious about racing again. I like the fact now that I can drive my car around when I want.
Old 02-13-2010, 11:14 PM
kbs71's Avatar
Well that's it,either you want the ultimate strip and go with the white body or sacrifice and go with the production and not excpect that much of a decrease in weight.
Quick Reply: Weight Reduction
