Weld Drag Wheels Now Available & In Stock For the 2010 SS!!
Old 02-01-2011, 09:14 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
Default Weld Drag Wheels Now Available & In Stock For the 2010 SS!!
Guys I'm proud to announce that Weld has now finished up the RT-S series wheels for the 2010 Camaros. We test fit the production version yesterday & I have to say these things are absolutely awesome! I also have to say I'm pumped up about how much cheaper these things are than the other drag wheel combos out there!
We've got a intro special going for all of you guys right now & even have black face & polished face wheels in stock!!
The wheels on our shop L99 car are the polished version, but we also have a black face option as well! The car in the pics have Hoosier 28" rears & M&H front 28" skinnies! This car lost 130# from swapping the GM 21" wheels to these Welds! If memory serves me correctly the fronts were 32# & the rears were 45#!
Here's the Link:
http://www.texas-speed.com/shop/cate...ID=11&catid=20
Here's some data:
Weld Racing brings its application flexible racing technology to the street with a budget friendly 3-pc modular wheel using a unique welded assembly process. This wheel has the classic Weld Racing 5-spoke star look and continues the Weld Racing tradition utilizing a forged billet center and cold forged rim shells. This unique wheel offers 3 mounting pad heights to clear specific drum and multi-piston opposed calipers. Target applications for this wheel include cars from the 1950's through today's challenging modern applications such as the 4th generation Camaro/Firebird, C4 to C6 Corvette, 2010 Camaro, and the Cobra Mustang.
SAE J2530 Aftermarket Wheel (Street) Standards
Center is available in polished or black anodized
Wheel widths from 4.5" to 18" with a wide variety of back spacings
Load rating of 1580 lbs per wheel (3160 lbs per axle)
Requires conical lugs
Center cap and valve stem included
Made in Kansas City, USA
Here's a few pics for you guys to checkout!:
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 02-02-2011, 09:35 AM
Jon@Texas-Speed's Avatar
Here's a vid of Greg Smith from Weld talking about the wheels.
http://www.youtube.com/watch?v=OyjMKdYTNFA
Old 02-04-2011, 11:51 PM
4doortypels's Avatar
looks like business in the back
Old 02-05-2011, 10:51 AM
bowtienick's Avatar
Now I know what to get with my refund check! Been waiting for these to come out.
Old 03-22-2011, 11:19 AM
Sales2@Texas-speed's Avatar
We've got many sizes in stock and ready to ship! Let us know if we can help!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 03-26-2011, 08:21 PM
DietCoke's Avatar
Update, looks like 13.2 pounds saved per side.
Stock Rear Wheel/Tire @ 67.4 lbs with lugs
RT-S Rear Wheel with 295/45/17 Mickey ET Radial @ 54.2 lbs with lugs
That's 13.2 pounds rotating mass per rear wheel saved, the fronts will be much more. Not too shabby considering it's much wider rubber, and the weight is MUCH more centrally located then the stock monstrosities. Shame I cant run 15s, but these HUGE brakes... LOL
Old 03-27-2011, 02:22 PM
Petraszewsky's Avatar
Would love to get a set of these to clear the C6 ZO6 brakes.....
Old 03-28-2011, 10:47 AM
Z06 brakes on another vehicle, or on the Z06? They do make them for the C6 Z06's and ZR1's!
__________________
Old 03-28-2011, 09:32 PM
Z06 brakes on another vehicle.....As long as they fit over the Z06 brakes they can make them in any backspacing/offset correct?
Old 03-29-2011, 06:46 AM
waterproofer's Avatar
do you still have a set in stock?
Old 03-29-2011, 10:08 AM
I do have several sets left in stock and another stocking order on the way soon! Let me know which style, size, and color you want and I can check stock for you!
__________________
Old 03-29-2011, 10:09 AM
They can make them how you want, but Weld, not Texas Speed, can guarantee the fitment of "custom" sized wheels that they have not tested at their facility! If you ordered a custom backspacing and such, and it didn't work, they won't take them back.
__________________
Old 03-30-2011, 05:02 AM
silver2010's Avatar
Received my new weld wheels yesterday and they look great. Just a heads up to those waiting on them, the stock lugnuts are to big in diameter to fit these. Pepboys has some mcgard ones that fit.Also you need a 7/8 thinwall socket.
Old 03-30-2011, 08:42 AM
DOH!!! I guess I had better measure correctly then and hope I get it right...If they know what the wheel's pad height needs to be for a certain brake application then I'm sure they would get that part right. And since the distance from the hub mounting flange to the outside edge of the caliper doesn't change the only thing changing is the backspacing/offset correct?? So if I know the backspacing/offset I need for any given wheel width then I should be fine....Am I wrong??
Old 03-30-2011, 10:00 AM
Honestly, I'd call Weld and pick their brains on that one. Your logic makes some sense to me, but I don't want to tell you yes or no on that without hearing it from them.
__________________
Old 04-18-2011, 03:59 PM
heres some pics. remember to zip tie brake cable.
Attached Thumbnails Weld Drag Wheels Now Available & In Stock For the 2010 SS!!-lsx-001-1600x1200-.jpg   Weld Drag Wheels Now Available & In Stock For the 2010 SS!!-lsx-003-1600x1200-.jpg
Old 04-19-2011, 04:05 PM
one more pics
Attached Thumbnails Weld Drag Wheels Now Available & In Stock For the 2010 SS!!-untitled-3-1600x1200-.jpg
Old 04-19-2011, 05:50 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Hey Mike, what size tires/wheels you running there? Car looks great.
Old 04-19-2011, 09:50 PM
tires are 17 x 4 1/2 M&H - rears are M&H 17x 28 drag radials
wheels 17x 5 and 17x10
Old 04-20-2011, 01:07 PM
sweetC5's Avatar
God that is awesome, I wish I had the money for that! Anyone wanna give me loan
Quick Reply: Weld Drag Wheels Now Available & In Stock For the 2010 SS!!
