How to clean aluminum???
Foamy engine brite and a thick bristle brush, even a wire brush. Maybe try a grinder with a softer wire brush attachment. I'll google for some pictures. Make sure you are at a low speed and low pressure. It will even give it a bit of a shine.
If you are just wanting to clean it by hand, 1:2 simple green/water, let it soak for 20 seconds and take some 000 steel wool to it. It will suck because of all the crevasses, but it will get it clean. Make sure to rinse the simple green off with cool water after you clean a section or it could cause minute corrosion.
GTO or Corvette, or I guess it could be a Monaro!
