General LSX Automobile Discussion Non-technical LSX related topics.
4th Gen LS1 MPG's?
Old 06-09-2011, 02:28 AM
  #81
blue02formula's Avatar
I have a M6 with 4.11's in a 12 bolt and get 18 mpg city shifting at under 2500 rpm. I get 25 mpg highway with the cruise set at 78 mph with the t-tops out. When I had 3.42's I got 28 mpg highway with the tops out. Best I got was a good tail wind coming home from Montana. I had a fuel run in Wisconsin 78 mph with the tops out and got just under 31 mpg. The best I ever got with the 4.11's is 27 mpg.
Old 06-09-2011, 10:41 PM
  #82
i'm sofa king's Avatar
my last mpg was 15.647. my average is 14.45. i use 91 premium, but its got %10 ethonal in it.
its mostly city driving, and i try to keep off the gas, but that doesnt last long.
Old 06-10-2011, 12:11 AM
  #83
SLP IROC-Z's Avatar
25-26 easy on the highway with my 6 speed, driving around the speed limit, could probably get better if i went out of my way to try.
Old 06-11-2011, 10:20 PM
  #84
SSmith's Avatar
The best I have ever seen with my M6 car all highway (car is stock) 27.5 mpg hwy (cruise set at 70 MPH)
I guess if I would drive all highway at 60 MPH then 29 mpg could happen but who wants to drive that slow on the interstate?
Old 06-11-2011, 11:09 PM
  #85
Magnet's Avatar
MY best is 28.8 highway and 21.25 all city (keep the RPMs below 1300 with the M6 )
Old 06-11-2011, 11:20 PM
  #86
99_ls1_z28's Avatar
Im getting around 12.4 mpg in city only. Not getting on it not once
Old 06-13-2011, 01:10 PM
  #87
tcbecker's Avatar
12-15 with mods below, equal city/highway mix. I do have a heavy foot, but don't drive it like a racecar either.
Old 06-13-2011, 01:11 PM
  #88
motaboata's Avatar
Avg 16.5 City and HWY best is 21.5 A4 with stall and 3.73sgears
Old 06-13-2011, 02:05 PM
  #89
MrBluGruv's Avatar
If you drive on San Antonio highways during the day, you may as well count it as city driving.
I pretty consistently get right under 22mpg all the time, almost completely irregardless how I drive. Still better mpg than my Marauder got, and is much faster to boot.
Old 06-13-2011, 09:10 PM
  #90
T-Top's Avatar
Originally Posted by brians91formula
depends on how you drive it.
my car can get anywhere between 14mpg and 27mpg out of a tank.
Same here. Only mods are a lid & tune. It has 273s. Oh, and its an a4.
Old 06-13-2011, 09:42 PM
  #91
408ws6ta's Avatar
So all the A4 guys get 15mpg and the M6 guys get 27mpg?
That must suck!
Old 06-14-2011, 02:47 PM
  #92
udienow's Avatar
My previous and current f-body (both M6s with full bolt ons, everything else stock) both average(d) about 17-19 MPG combined (bout 240 miles a tank). This is probably 60/40 city/highway, not beat on but not babied either. I would say this is what a normal average driver should expect. But these cars can do better. On a trip back from Texas 98% highway at 75mph with tops off I managed to average 26mpg. The 6th gear is such a good gas saving gear, it really is up to how much highway driving you do and how hard you drive.
Old 06-14-2011, 10:48 PM
  #93
CoastieWS6's Avatar
I get 17-18 mpg city anf 27.5 mpg HWY
Old 07-18-2011, 03:36 PM
  #94
HibachiZ28's Avatar
Since I posted this I picked up the 98. It's getting 14.4 average City/Highway and that's not really getting on it much. The car is putting down 310hp and 320 lb. ft. of torque to the wheels per my Dyno run last week. Any recommendations to boost my MPG? Just cleaned/re-oiled my K&N.
Old 07-18-2011, 03:48 PM
  #95
1996firebirdformula's Avatar
Shift before 2k rpms. Have tried sea foaming it? Might need tuneup also. Plugs,Wires,Fuel filter. whats Tire pressure at?
Old 07-18-2011, 03:53 PM
  #96
sandsk8erz400's Avatar
One tip I learned the hard way did have to deal with the K&N. I know it's pretty common knowledge on the forums here and judging by how long you've been here my post will probably be useless haha. But when I was younger I always over oiled the K&N not knowing any better. All the extra oil built up on the MAF but with a good cleaning it was all back to normal.
Also, depending on how bad the city driving is, those numbers seem reasonable for an A4. I'm an M6 and when I drive in the city it's really stop n go with a lot of lights. Shifting under 2K the whole tank, best I've managed is 14mpg. I'm also all up to date on the maintenance and can pull 29mpg on the freeway so it's all in the situation.
Depending on how many miles, could clean the top end with some of the MCCC (mopar combustion chamber cleaner) I think that's what it stands for haha. Plugs and wires are a possibility too.
Best of luck
edit: misread the sig, saw the A4 is sold and M6 is present. I'd suggest trying what 1996 and I have said. Personally, I'd go with the MCCC over the seafoam from all the threads I've read on here, but thats just IMO.
Last edited by sandsk8erz400; 07-18-2011 at 03:56 PM. Reason: don't know how to read sig haha
Old 07-18-2011, 04:45 PM
  #97
senicalj4579's Avatar
Update. IDK if its the quality gas or the warmer weather but I have been getting 20-21mpg with wot, city, and highway combined. Its gone up about 1.5 mpg.
Old 07-19-2011, 09:49 AM
  #98
HibachiZ28's Avatar
Thanks guys. Plugs and plug wires are on the list as I am unsure when they were changed last. I just oiled my K&N filter last week with the normal amount of oil (just 'til it turns red as stated). I used to work for Mopar, and I still work for a Jeep parts company, so I contacted my buddy at the dealer I worked at to see if he's heard of this MCCC stuff. I personally haven't, but if they have it or can get it, I get it at cost which is nice. I just started trying the low RPM shifts. Damn skip shift is still on my car and it's causing me to grind now and then as I forget. I usually wind out my RPM's to 3-5K before shifting, but we'll see how the sub 3K stuff works out. I know I get approx 200-225 miles out of the tank before the gauge hit's "E" (I know there's more gas in the tank, but this is the average miles out of my tank that I use each time I fill up).
Old 07-19-2011, 10:10 AM
  #99
Element's Avatar
Best ever, when the car was stock, was about 33mpg. Night driving, flat highway with no traffic, cruise control at 65mph.
Normally 10-12mpg city, 22-27mpg highway. Gotta love ethanol (gag).
Old 07-19-2011, 10:54 AM
  #100
prochargedpony's Avatar
With my mods I usually average about 17-19, if I get into a few highway tussles usually about 15, My long trips I get 27 all highway, thats with 3.90's and a full spool 9inch. They get decent gas mileage for what they are.
Quick Reply: 4th Gen LS1 MPG's?
