general advice for a 425-435 rwhp dd
hello , moving forward into the new year i want to aleast up my z28 up to atleast 425 pushing it 435 rwhp dd my current mod are ls6 swap , texas speed lts & ory pipe , borla exhaust , slp lid ls6 intake , and a 3200 stall , the stall isnt installed yet , but now my question is which route should i take f/i or bigger cam ,since im moving next yeat my budget is around 1500-2k , im open to all advice thanks
For your goals n2o may be the answer.
pros: Stock fuel economy and it is SAFE with a good tune and moderate shot. No hard cold starts, surging issues, wear/maintenance associated with the stuff needed to run a big cam. Your stall is a good match too.
cons. An improper tune and n2o will cause problems on any motor. These motors are especially susceptible to broken ringlands (see picture of my H/C stock motor...)
If had it to do all over again I would prolly have done n20 first as that ringland would have busted anyway and now I would have an n20 403 lol..
I'm guessing your current power level is around 360-370 rwhp so to reach
your target goal is only about another 60 ponies. The problem is thats a
pretty tight budget. I'd send those heads to Advanced Inductions for a
$1000 cnc program w/valvejob and mill. They use PSI maxlife beehive springs
or Lunati duals and can spec you a cam in the 230 @ .050 range. With new
head bolts, gaskets, push rods, and a Comp rocker trunion upgrade your
budget will be toast. Might have to collect aluminum cans to pay for a new
tune but you'll have the power you seek AND the daily drivability.
I could prob, save up an extra 1k or so bring the budget up to 2500-3k , I like the ported heads n cam option , what's the turn around time when I ship ,my heads out to get ported,
1.5-2K being the budget.
Torquer V3 Cam w/ 114LSA (Because it's a DD) - $375
Pushrods - $80
Oil pump/ Timing Chain - $350
Tune Approx - $500
Brings you in around $1350 + Shipping. Well under your budget, but it will net you about 400 RWHP. To match some heads with that will pick you up into the HP range you want. Heads are $1400-2700.
Others are talking about nitrous, you could go that route too. N2O is around $6-700. I've never had any good experiences with Nitrous (improper installs, blown motors, etc), however, a proper tune, and a proper install have always been the key.
Pushrods - $80
Tune Approx - $500
The major negative to nitrous...and I've run plenty of it...is the continual
expendature of refills. You can't run a bottle empty cuz the pressure drops to
the point where the kit goes maga fat(rich)...@ 5 bucks per pound and the
necessity to keep it warm (900psi) is a constant battle. It makes awesome
torque and power but requires extreme attention to detail.
Pushrods - $80
Tune Approx - $500
Pushrods - $80
Tune Approx - $500
My buddy with heads (i forget which ones) and these mods is pushing 465rwhp
I have never run it on an LS motor but to me cost is not a good argument against N2O. A cammed motor loses mpg every time you crank it up not to mention the extra valvetrain wear. A N2O motor can easily hit his goal bone stock and he would have to hit the button alot to offset the extra fuel H/C car would burn.
Also looking at cost be realistic... a good kit including a window switch and FP safety switch, bottle warmer and for street use bottle opener is more than $6-700 but deals can be had in the classifieds here.
A 100 shot on a stock motor with a good tune is extremley safe and cost effective IMO. Consider a stock ported H/C package with full supporting mods for say $1800 may not get you quite 100rwhp and N2O starts to look good....
EDIT: My response to cost above was to a post now deleted that said a nitrous kit was $6-700. A basic kit yes but a kit I consider adequate no....
Captain Double Post
my vote is fi, slap a d1sc on there, i honest wish i would have just got a procharger to start, imo it would have been cheaper in the longrun , will also give you lots of room to grow if you ever wanted more, add a decent boost cam and you will be a very happy camper lol, a cam is a good upgrade, that is what most people get after bolts ons, like i said if i could start over again boost would be my number 1 goal, i had a procharger on my mustang and they are great, i drove that car alot
