engine swap ?s
engine swap ?s
Im going to be swapping a 2000 long block into my 98 and i was just wondering if some parts are the same. Do i need a different Oil pressure sending unit as well as knock sensors and harness because I see that there are 97-98 and 99+ parts. Also, because i have a 98 with the coils on the valve covers, caa i use the same coils and just get the brackets or do i need to get all new coils with the brackets already attached?
not only will you need a coil pack bracket or relocation kit but i would recommend getting a wiring harness for them aswell. i just installed some 806 parameter bolt heads and valve covers on my 02 (well worked over heads) and used the stock coil bracket. i was able to reuse my 02 coil harness but that made it difficult. the wires get stretched and really tight and they install in the reverse order as 99+
the computers being different shouldnt make a difference should it seeing as its the same motor?? I should have mentioned this but i have the 99+ valve covers already. So theres no way I can just get the brackets and see if theyll work and just mount them and plug them in?
You will have to reuse the sensors off the 98. The watertemp on a 98 has 3 wires and the later models had 2. A 99 CPU is wired different than a 98s. So your gonna have to keep the 98s cpu and wiring, reuse your 98s sensors and you might have to put the 98s injectors on it also. They are 28.5# and I think the 99s went to 26# injectors.
