... I need a car lift.
Spent tonight taking off my x-pipe and exhaust on my C5 Z. What a pain in the *** this whole operation was!
I had to gut the cats on my American Racing headers, because of the new nitrous setup. So, I jacked up the back of the car and let the fun begin. It ain't easy crawling under one of these things, especially when they're lowered.
Sounds a lot better now without the cats on them too. I'm happy with the results. Saved $400 by not buying a non-catted x-pipe from ARH and I still have the catelytic converter shells on there for visual inspections.
Anyway, I will be making sure to order a lift to make things easier in the near future, because crawling under this friggen thing ain't fun!
Here's a short video I took of it after I got it out of the garage.
http://i1183.photobucket.com/albums/...2/e9e15e52.mp4
It's got a cam/head setup on it also. Just figured I'd post up a new video of the car.
2x4 cut 14" and screwed together - 2 screws at each end of board. Some guys use glue also but it's not needed. You can make these just about any height you need assuming you are able to jack it up high enough.
I used 2 pair of the 6 ton heavy duty jack stand and the 2 ton low profile race jack from HRB to get my car around 2 feet in the air. I am nearly 6'2 and the engine bay was chest high and I needed footstools just to reach inside the engine bay. Being a large person I used a creeper to do my entire exhaust with absolutely no crowding issues at all. It is easy to get the car high enough in the air.
Oh yes, they worked quite well. I could turn my headers 90* and then some. Swaping a rear or K would be no issue so long as I had something else to hold the engine up or a stand for the rear. It just sucks laying down doing all that and the rolling back and forth. When I purchase a perm house, you better believe once of the first purchases will be a damned lift.
