porting ls2 intake
thanks for input
i would not put a stock ls2 intake on, it isn't stock the intake is ported,only thing left to do is the throttle body opening and get this i'm taking a ls6 intake off along tith the 80 mm throttle body to get about 10 more hp and torque ---------------
Why not just a regular 90-92mm LS2/LS3 or aftermarket throttle body?
A 102 TB is going to once again be pointless for feeding an LS6 intake. If you have good heads and big cam, the restriction isn't going to be at the TB but in the intake manifold itself.
And if you don't have good heads and big cam for the intake manifold to be a restriction, then there's no reason for a 102 TB.
