tach mounting
could get some velcro. stick one side to the tach, the other to the dash. or 3m double sided tape. it can be removed and installed alot easier with velcro tho. just clean both areas with rubbing alcohol to remove any oils so it will stick and not come flying off the first time you nail it.
Yeah do a raptor light in the vent etc. If your set on a 5" mount it on the plastic bezel that is around the gauges. Those can be pulled off and replaced. Have it leaning off to the side.
In my opinion those big ugly 5 inch tachs only belong in NASCAR stock cars, and I don't like NASCAR. Ricers put them in their civics, they stick out like a sore thumb, they junk up the dash, and there really is no use for them. Just get a shift light and put it in your vent, on the column, or I have seen them in the kick panel by the upper leg area. Just as long as it's in your peripheral sight then it will work.
