New car coming - what should I do?
Hi All,
I just purchased an 02 Firehawk with 47k miles. It should arrive late Monday (waiting is killing me!) and I should be off work on Tuesday.
Is there anything I do before driving the car? I mean other than check the basics like fluids? The prior owner said he changed all fluids but I wasn't sure if you guys had a check list of things to do in such a case.
Thanks!
Thanks!
If you have a mechanic you trust I would take it there first thing. It's best to know what you have on your hands before you drive it like crazy. I bought a 96 Z28 with 50,000 miles and at first it was immaculate but shortly after the AC compressed went out, front shocks gave out, and the battery died on me. Good luck with your purchase and take some pictures for us.
I will defin post some pics when it gets here.
Are you mechanically inclined at all or have space to work on it? If so I would just pull a couple plugs and look at them, if it's a m6 change the clutch fluid, a4 do a pan drop and filter change. Wouldn't be a bad idea to change the differential fluid eventually either.
A visual inspection will defin happen. I'll check the belt and hoses as I think they may be the original ones.
98CayenneT/A - yes I am although my experience is mostly with older muscle cars but a lot of it still applies. Just trying to get up to speed with an fbody/LS1.
Good call on the plugs. And it's an A4. Seller said he was changing all fluids but I will have to check myself.
Thanks!
Thanks!
LS1Tech Administrator
Received 1,795 Likes
I wouldn't pay a mechanic to check it over at this point, that would only make sense before you buy it, then you can use that information for negotiation purposes or to simply rule the car out. It's yours now either way, so might as well save that money for any repairs that actually present themselves as being needed. If you are at all experienced with automotive and mechanical basics (sounds like you are based on the above posts), then you can do a simple cursory inspection yourself and skip the mechanic's fee. This is all that's needed before the first drive, and then depending on how that drive goes you can decide if there are problem areas that require more comprehensive evaluation by either yourself or a professional.
Best bet would be to report back here if you find issues. Many of us are highly experienced with these cars and can offer help/ideas in terms of diagnostics or common solutions to problems you might encounter.
Congratulations on the new car and have fun with it!
The seller did disclose a few things so I know a few needs but that's why I got a good deal on it.
- front driver side corner of the hood has some paint loss
- both window motors need replacing but it comes with one
- rims are pitted
Other than that it's really nice.
I plan on doing the initial inspection and fixing the windows and then working on the window motors (I found articles here to help), painting the hood and possibly re-chroming the rims if reasonable.
Thanks. I will be sure to post pics when it gets here (hopefully Monday night).
- rims are pitted
There are some posts in the last month or so on important things to check/verify. You can find those in the "general maintenance" or "New LS1 owner" forums. Firehawks seem to often come with the Auburn differentials. So if the last owner just changed that fluid hopefully it was with conventional oil + LSD additive...or else excess noise could result. The power steering cooler on these cars is problematic. So I'd plan to take that out or at least neutralize it in the very near future (see sticky thread in "gen'l maint."). Whatever is currently being used for antifreeze, I'd stick with it (orange DexCool or the regular green stuff). Fuel filters are often overlooked too. The roof sail panel paint on these cars will bubble/blister the longer they sit out in hot sun. Something to be aware of and manage/avoid. The plastic upper door panels develop a stress crack over time that will eventually travel over the entire panel. There are threads on how to stop it. If yours doesn't have them yet at 47K miles, you're beating the odds.
Good reminder about the fuel filter^^ That's an easy one to forget about.
I'll add one more thing to check and it could be a lifesaver. The age of the tires. Look for the date code on each tire. I'm sure you want to take the Firehawk on some 'spirited' drives so it must be done on newer quality rubber. If the tires are 6 years old or worse, dump them and make the effort to get a quality set like Goodyears or similar upper end name brand. Have fun!!
Meckeard, congrats on your new pick up. I also saw you were interested in that red 2002 FH with 21K miles in Connecticut (Ebay at end of July). I'm curious if you actually went to see that car or decided against it for any particular reason. Always interested in what's in the thought process of today's buyers. Thanks.
Firebrian - thanks. Car won't get here soon enough.
Yeah I recall that FH and wanted it. It looked sharp and was a good deal. My issue was that I couldn't get my financing in order before the end of the auction as I found it too close to the end. No other reason. Did you buy it?
