Does my 2000 SS have traction control?
Here's a list of the options off the door sticker. I don't see the traction control option NW9 on my sticker. But my car has the ASR button on the dash yet it doesn't light up and the button just pushes in and releases, it doesn't stay clicked on or off. So do I have traction control? I'll test it out tomorrow morning on the way to work to see if the wheels spin)which I know they do but I always push the button thinking I had ASR).
RPO Decoder/Revealer Results
AG1 ADJUSTER FRT ST POWER, MULTI-DIRECTIONAL, DRIVER
AK5 RESTRAINT SYSTEM SEAT, INFLATABLE, DRIVER & PASS
AR9 SEAT FRT BKT, DELUXE
AU0 LOCK CONTROL, ENTRY REMOTE ENTRY
AU3 LOCK CONTROL SIDE DR, ELEC
A31 WINDOW POWER OPERATED, ALL DOORS
A90 LOCK CONTROL RR CMPT LID, REM CONT ELEC RELEASE
B35 COVERING REAR FLOOR MATS, CARPETED INSERT
B84 MOLDING B/S EXTERIOR
CAE HANDLING CHARGE GM ST THERESE TO SLP LASALLE QUEBEC FOR UPFITTER CONVERSION (VTIMS)
CC1 ROOF HATCH, REMOVABLE PANELS, GLASS
C49 DEFOGGER RR WINDOW, ELECTRIC
C60 HVAC SYSTEM AIR CONDITIONER FRT, MAN CONTROLS
DE4 SUNSHADE REMOVEABLE HATCH ROOF
DG7 MIRROR O/S LH & RH, REMOTE CONTROL, ELECTRIC, COLOR
DL5 DECAL ROADSIDE SERVICE INFORMATION
FE4 SUSPENSION SYSTEM SPECIAL RIDE & HANDLING
GU5 AXLE REAR 3.23 RATIO
G80 AXLE POSITRACTION LIMITED SLIP
IPB TRIM INTERIOR DESIGN (PB)
J65 BRAKE SYSTEM PWR, FRT & RR DISC
K34 CRUISE CONTROL AUTOMATIC, ELECTRONIC
K43 GENERATOR 102 AMP
LS1 ENGINE GAS, 8 CYL, 5.7L, SFI, ALUM, GM
MX0 MERCHANDISED TRANS AUTO PROVISIONS, O/D
M30 TRANSMISSION AUTO 4 SPD, HMD, 4L60-E, ELECTRONIC
NC1 EMISSION SYSTEM CALIFORNIA, LEV (NOTE: NOT TO BE USED AFTER 2007 MDL YR FOR DOMESTIC NAO PASS CAR & LT DUTY TRUCKS)
NG1 CERTIFICATION EMISSION, GEOGRAPHICALLY RESTRICTED REGISTRATION FOR VEHICLES UP TO 6,000 LBS GVW
NP5 STEERING WHEEL LEATHER WRAPPED
N73 WHEEL CUSTOM SPORT, VAR 4
PBT IDENTIFICATION TEMPORARY HOOD FOR UPFITTER DELIVERY
QFK TIRE ALL P275/40R17-93W BW R/PE ST TL HW4
R9Z CONTROL SALES ITEM NO.100
STE PLANT CODE ST THERESE, PQ, CANADA
T82 HEADLAMPS CONTROL AUTOMATIC ON-OFF
T96 LAMP FOG, FRT
UA6 THEFT DETERENT SYS
UB3 CLUSTER INST, OIL, COOL TEMP, VOLTS, TRIP ODOM, TACH
UK3 CONTROL STEERING WHEEL, ACCESSORY
UN0 RADIO AM/FM STEREO, SEEK/SCAN, CD, AUTO TONE, CLOCK, ETR
UZ7 SPEAKER SYSTEM 8, QUAD FRT DR MTD, DUAL SAIL PNL, DUAL RR HATCH, AMPLIFIER
U73 ANTENNA FIXED, RADIO
VM3 LABEL INFORMATION CONSUMER, CONTAINS BPR IMP STANDARD FOR FRT 5 MPH & RR 5 MPH
V12 COOLING SYSTEM POWER STEERING, FLUID
V73 VEHICLE STATEMENT USA/CANADA
WU8 SALES PACKAGE CAMARO SS APPEARANCE AND PERFORMANCE, SINGLE LABEL
Y2Y SALES PACKAGE CAMARO SS DUAL LABEL
Z28 MERCHANDISED PKG SPECIAL PERFORMANCE
1AZ ORDER MODIFICATION ORDERS SOLD
1SD PACKAGE OPTION 04
1SZ DISCOUNT OPTION PACKAGE
10Q MOLDING COLOR ARCTIC WHITE (91)
10U PRIMARY COLOR EXTERIOR, ARCTIC WHITE (02)
6ZL COMPONENT FRT LH COMPUTER SEL SUSP (6ZL)
7ZL COMPONENT FRT RH COMPUTER SEL SUSP (7ZL)
8TJ COMPONENT RR LH COMPUTER SEL SUSP (8TJ)
9TJ COMPONENT RR RH COMPUTER SEL SUSP (9TJ)
92B TRIM COMBINATION CLOTH, PEWTER (B) (97)
92I INTERIOR TRIM MED DK PEWTER (97)
T96 LAMP FOG, FRT
well ive mosly seen non ASR camaros with the dash button non existant. the button hole will have a cover with no writing on it, or no light.
on the passenger side strut tower, do you see a little black box? if you do then you have ASR.
Nope, no black box on the passenger tower. I think I see where it looks like it would be installed. But I definitely have the ASR switch in the dash next to the fog light switch. But it doesn't actually click on/off, it just pushes in and releases and it doesn't light up at all. I guess I have the rare fake ASR option!
Nope, it's a mostly stock SS. The SS badge is right next to the ASR switch so maybe that dash panel got mixed up with a car with ASR at SLP when the car was built. So somebody else has traction control with no switch to turn it off! That would suck.
thats the flux capacitor button. or maybe it was the nitrous button contradicting the "traction control" meaning it has.
Originally Posted by SlowTA367
I still say e-cutout or, God forbid, neons. Dunno why else it would be there. Have you taken the switch out to see if there are actually wires running to it?
All that being said if you don't have that little black piece mounted above the battery then you don't have it any longer, just thought that might clear it up for you in case you would like to put the ASR back in the car.
There's no other sign of ASR ever being on the car and it's not on the RPO doorjamb sticker. The 'ASR' letters do light up when the lights are on so it might be plugged into the stock harness. I'll check it some day when I dig into the dash to disable the automatic headlights.
Maybe the asr switch is to turn on the fans manually. The guy before me used another foglight switch for it. I also have traction control. I have three buttons: Foglights, ASR, & fan control.
Well, I pulled the dash surround section off and the ASR traction control button is plugged into the wiring harness! And I definitely don't have traction control. But my car has the stupid automatic headlights. Is there supposed to be a disable switch for the auto headlights? I thought maybe they put the wrong switch in my car.
