02 Camaro Headlights?
during the day you can, but at night once you engange the car (put the Ebrake down or shift to drive) they will turn on automatically, you can turn the interior lights off with the dimmer switch but not the headlights, must be a senor
Yes, you can shut off the lights, anytime you want.
With the car shut off, pull up one click on the e-brake, enough to engage the switch (under the console). then leave it there & start the car. No lights. If you want lights, you can then use the manual switch. If you happen to push the brake lever down, the lights will go back to normal, & you'll have to shut the car off & start over.
Originally Posted by Black02LS1
Is there a way to manually turn the headlights off on these cars?
Cool...thanks guys..but does anyone have any pics or diagrams of this? I know where the little sensor is in the dash, but i dont know how to pull the dash apart and which wires to splice in and everything.
LS1Tech Administrator
Received 1,492 Likes
Try this link.
http://www.xse.com/leres/ss/drl.html
I opted to ditch both the DRLs and the auto headlights. I like manual control over all my lighting.
I know in the newer Tahoes with auto lights if you push the Dome override button multiple times with the automatics lights on and the switch turned to "off" it will chime and turn to manual mode.
Id figure things out before you start disecting(sp?) your dash.
