Name that part
Name that part
what the hell is the trim on the outside of the window called thats at the top of the door. the stupid clips are messed up and when i roll up my window it pops up and i cant get it back down unless i take the door pannel off inside and bend them back i need a new one its scratching my paint!!!. anyone know where i can get one and what its called?
dont have a camera the back rubber strip at the bottom of the window and top of the door. take your hand put on door handle move it up till u hit rubber that thing if you make it to glass youve gona to far. its got the felt on the inside that goes on the glass.
I had the same thing happen to my 94 firebird. It's the outer window door seal. All I know is that it was way to expensive to fix so when I had the door panel off I used some epoxy to glue it in place.
Yep, call the dealer, get the PN for the outer window door seal for the drivers side door - then goto gmpartsdirect.com and order it from there.
-Eagle
-Eagle
