Should a 43,000 mi LS1 look like this???
Hey all,
I don't have much experience with LS1s; every engine I've worked on up 'til now has been cast iron. So...I pulled the oil pan on this motor to swap out rod bolts & install a modded oil pan, and I saw the nastiness below. This looks like crap to me, but I have no experience with an aluminum block and thought maybe it stains easier (but the crank is just as nasty & it's iron!!??). Does this look normal for a 40,000+ mile lower end? Looks to me like it's seen one oil change- at about 10,000 miles. Any recommendations for cleaning without totally tearing it down? THANKS IN ADVANCE!!!
Breeze
Breeze
looks like someone used crappy oil and never changed it. have you ever checked under the valve covers for sludge. While you have it open like that get some sea foam deep creep and clean it up. then you can some some regular sea foam through it later to get the rest if there is any.
Originally Posted by Silas2k
in america they tell us 3 months, 3000 miles... in europe they tell them 10,000 miles... hmm
Originally Posted by blk97z28
hey i hacve a qestion what should I change my synetheic oil at? I have maybe put 120 miles on the car since then and it has been about 2 months?
