Porting 806 heads..Worth it
i searched and could not find a Straight answer so hopefully you guys can help.
I just had some engine trouble so im pulling my engine to install some forged pistons and what ever else needs to be replaced.I would love to go ahead and stick some aftermarket heads on but i doubt i will have the extra cash flow to finance them.But i will be taking my block to a machine shop to check it out and make sure its not cracked and may have him work my 806 heads.
Would it be benificial to me and my mods that i have now ,any suggestions or Input is very very welcome.
Lt headers and xpipe
BBk ssi intake
Supporting valvetrain mods'
Torqer v2 cam
pp tb and MAf
air lid.
my car did 370rwhp with these mods and stock 806 heads
BBk ssi intake
Torqer v2 cam
pp tb and MAf
air lid.
The main reason is i see alot of cars with my same mods but the 01-02 heads that have around 10-20 more hp than me and this is the only thing that i can come up with .If i could port them and make them atleast on par maybe a hair better than the 241 heads i would def do it .i can get it done at a fairly good deal
OWN3D BY MY PROF!
The only difference between the 806 and the 241 is the casting finish. Porting 806 heads are worth it. I have an extra set of 806 heads set up for a solid roller setup that are very nice. If you have any technical ability what so ever I'd just buy an extra set of heads for $100, read up, and port them yourself.
hey thanks man for sheding a little light for me.I may have him do them for me.I think he will do me right i have delt with him for years when me and my father ran a local shop.
What exactly did you have done to your heads when you ported them any insight you can give .Because i will in turn tell him what i want done .
LS1Tech Administrator
Received 1,493 Likes
Yes, port the 806s. The 241s will flow a bit better stock for stock, but once both are ported, the 806 and 241 are equal, assuming the porting job was equal.
sounds good thats what i wanted to hear,any sponsers you would recomend to do the work .
if i can find it resonable i will just ship them off and have them done with a sponser or someone that knows these heads in and out
OWN3D BY MY PROF!
