!?! Dex Cool & Power Steering !?!
This **** is really annoying me now! I need some direction..
1. power steering fluid is getting in my coolant reservoir!
2. a mix of power steering fluid and dex cool is getting splashed under the hood in an area right above the power steering reservoir. (orange like coolant but feel like fluid)
there are NO signs of liquids or fluids ANYWHERE on any parts, but mysteriously shows up sprayed and splashed under the hood. WHATS GOING OOONNN????!!!! What els should i check, look for, what would i need to replace??
I don't think PS fluid can get into the coolant. But tranny fluid and oil can.
o yea i figuerd power steering cooler but what im really looking for is if any1 had any similar problems and the steps they took to fix it. imma attempt to tackle this problem this weekend just need some direction
So, make sure its not tranny fluid. Tranny fluid will get into your coolant if you have a tiny crack in the radiator.
Make sure your water pump is not leaking from the gaskets or from the bottom of the pump in the center.
maybe ill have to dig deeper to check those spots out but as far as i can tell even after i cleaned the whole engine bay theres nothing on or around any of those parts, only shows up under the hood, this what makes it so mysterious. ill use dyes in the fluids and report back tomorrow
its the power sterring cooler replace it. in case you didnt know your power steering cooler is cooled by gues what COOLANT. see that silver thing in line with your upper radiator hose with 2 lines going to it from your power steering pump that is your power steering cooler and it is bad. replace it
1 Post
+2 power steering cooler and check the power steering cap there would usually be a crack around the top edge of it that starts and will usually leak out and there would be no sign, or it could be your overfilled on PS fluid and it is spilling out
