Steering wheel wobbling =\
Hey guys I'm havin a problem here. My steering wheel moves up and down when you pull on it and it feels like the whole column moves with it. I wouldn't care normally but I'm about to put a Grant wheel on and I wanna go head and fix it. Also, I was told that the wobbly columns will mess up the VATS which is believable because I've already had to pay $280 to have a VATS short fixed and the problem is comin back a year later. What do you guys suggest? Thanks in advance
I rebuilt my column, completely. It took about 5 hours. Removed every part. Cleaned and checked it out. Replaced what was needed.
Can the wheel be pushed around in all direction? Up, down, left, right? Or it is only up and down?
Does it only do it in certain tilt positions?
Well it only wobbles up and down for the most part. I would get a dealer to do it but I'm broke. I'm very mechanically inclined though so I just need to know what to fix and I can probably do it. I'm in a "fix up all the small things wrong with my car" mode. I've fixed PS, AC, Mounts, lowbeams, etc lol So now this wobble is next on my hitlist
It can be involved and difficult to rebuild the column. The hardest part for me is always depressing the tilt spring. It is a nice beefy one! But after a couple of rebuilds its a cake walk.
Thing is that it could be the tilt pawl mechanism. Try it in each tilt position and see if it does it in each spot! You can't really fix the tilt mechanism easily.
The other thing it could be is the base of the tilt mechanism is loose. You have to pretty much break the column down 100% to fix it.
The book price is around 300 to fix at a dealer.
There is a guy in Fort Wayne Ind that does it for about 70 plus parts.
This link is helpful!
http://www.fiero.nl/cgi-bin/fiero/sh...tyle=printable
1. take your old key figure out the vats number...
2. buy a new key with your old vats number
3. get new key cut to new switch cut from new column, that way you keep the same vats but its a new key and new column and your set ...
thats what i have been planning to do to my camaro but havent got a chance to do it yet. My tilt is shot to where my high beams wont even click on unless the tilt is all the way down sucks Someone before me used my steering wheel as a (ol grab) handle when getting in and out of the car, i guess lol
p.s. i got my info from a fellow ls1tech member who helped me out on my similar questions as well.....
i would agree though instead of taking the switch cyl out of the new column your wanting to put in the car u could ..........
Hm... my wheel does the exact same thing. What does it mean if the wheel has a lot of play though? Like I can turn the wheel a few inches left or right without the wheels moving.
ive just found out that it isn't always the screws at the bottom of the tilt base that contribute to play in the wheel. and you are right these columns are so plentiful that its easier to just get another one.
Up and down play could be the tilt mech pawls or the tilt base screws
