Oil pressure low, should I be worried? (pic)
Old 11-02-2008, 03:57 PM
02RedWS6RamAir's Avatar
Default Oil pressure low, should I be worried? (pic)
95 T/A with 124K.
Old 11-02-2008, 03:59 PM
LS6427's Avatar
I see you're already warmed up and at idle, thats not bad really. How old is your oil?
Is it like that on cold start-up too?
While cruising at say 45mph, is the pressure a little higher than that?
As long as you have pressure, you're good. And these gauges aren't the best either.
Old 11-02-2008, 04:19 PM
New Mobil 1
No, around 40ish on the gauge.
That's good to hear!
Should I consider replacing oil pressure sending unit?
As a footnote, the car sounds great and pulls hard. I've checked the oil and it's clean with no metal shavings.....
Yes, it's around usually around 40, give or take.
Old 11-02-2008, 04:28 PM
ls1passion's Avatar
i would replace ur oil pump because my buddys lt1 was exactly at the same spot as urs 4 about a month then failure he now needs a new motor.
his also pulled hard by the way just when ever he was at a stop or idling in park it woulg very low like urs.
Old 11-02-2008, 04:35 PM
That sucks. I really don't want to end up with a blown motor.........
Old 11-02-2008, 04:40 PM
How else can you test for oil pressure?
Old 11-02-2008, 04:57 PM
AFASTYZFR1's Avatar
I would cut open your oil filter to make sure your bearings aren't being chewed up.......If it was my car I would replace oil sender and oil pump if necessary.
Old 11-02-2008, 05:10 PM
Do you know how much it is to replace an oil pump?
Old 11-02-2008, 05:14 PM
ls1passion's Avatar
not 100% sure but i think around 300$.
Old 11-02-2008, 05:23 PM
K, Thanks.
.......should I not drive it?
Old 11-02-2008, 05:25 PM
AFASTYZFR1's Avatar
K, Thanks.
I wouldn't.....until you figure it out
Old 11-02-2008, 05:26 PM
AFASTYZFR1's Avatar
whats the pressure while crusing at 2k rpm's?
Old 11-02-2008, 05:30 PM
At highway speed, the guage reads around 40.
Old 11-02-2008, 05:41 PM
AFASTYZFR1's Avatar
hmmmmm.......I honestly don't know.....maybe it's fine for having that many miles......but if it was mine, I would replace oil pump and sender for peace of mind.......I would feel alot better with oil pressure at 40psi at warm idle
Old 11-02-2008, 05:43 PM
....I tend to agree.
Old 11-02-2008, 05:53 PM
Anyone else have any input?
Old 11-02-2008, 06:40 PM
samson_420's Avatar
Run a mechanical gauge and get exact readings. If they still suck, start looking into it further(new oil pump and internal engine work).
Old 11-02-2008, 10:53 PM
LS6427's Avatar
The Mobil 1 by itself will drop your oil pressure, its thinner. If you're at 40 psi while you're cruising, you can't ask for anything better than that. Also, if you're at 40 psi on cold start-up when idling, thats GREAT!
As said though, it can't hurt to cut open a filter, but you are just fine.
One thing I would do, like "samson 420" said, get a true reading with a different gauge, that'll give you piece of mind. Its probably gonna read the same because its Mobil 1 synthetic.
Old 11-02-2008, 11:09 PM
Right now it's got Mobil1 5w30.
I think I'm going to try the Mobil1 10W40...............
Old 11-02-2008, 11:11 PM
stevied916's Avatar
try a full synthetic. mobil 1 isnt full anymore even though the bottle says it is. mobil 1 tends to thin alot when hot
Quick Reply: Oil pressure low, should I be worried? (pic)
