Problem...Short video
Old 04-11-2009, 07:25 PM
firechicken76's Avatar
Default Problem...Short video
http://www.youtube.com/watch?v=Cca5RXIinrU
ok, the problem is when i push on the gas the car "shutters" I dont know what other term to use, if you listen close i do it about 3 times, this was taken in high gear, but will do it in any gear, i wouldnt say its WOT, just general acceleration, car drives fine, unless i want to accelerate.
Old 04-11-2009, 08:18 PM
anyone?
Old 04-11-2009, 09:04 PM
LS6427's Avatar
hmmm, failing 02 sensors cause that, and you won't necessarily get an SES light.
Maybe some kind of clutch issue, don't know a whole lot about manuals.
Does it rev perfectly smooth all the way up to like 5,000 rpm in "Park" or "Neutral".
Old 04-11-2009, 09:42 PM
seems to do it when it has a load against it, the heavier the load (6th gear) the easier it does it, havent thought about it being the clutch, any other thoughts?
Old 04-13-2009, 01:11 PM
anyone else? i changed o2 censors and it didnt seem to do anything...HELP
Old 04-13-2009, 03:29 PM
MiniTransAm's Avatar
My 2002 WS6 did that in 6th gear when I had cylinders 5 and 7 go out on me. Other gears it was OK. I had no other symptoms from the engine. Thought it was normal because I was "lugging" the engine a bit. Then one day I was accelerating up a hill and my check engine light started flashing. A few months later, a new short block went in. Not trying to scare you, but the shifter wiggling like yours does is exactly what mine did. A compression check confirmed they were dead. How many miles on the engine?
Old 04-13-2009, 08:13 PM
it may be a spark plug loose, when we did did headers we pulled a few of them, and put them back in, we were limited in space and i thought we got them all in.
Old 04-13-2009, 08:20 PM
Yeah, check all that stuff first. Hopefully it something stupid like that. Good luck!
Old 04-13-2009, 09:50 PM
it was a plug, i guess when my friend and i did the headers he didnt put it in all the way.l... go figure, anyway, pulls like a raped ape now, thanks for your help!
