creaking on turns
Old 07-15-2009, 09:13 PM
shutzero's Avatar
Default creaking on turns
so lately when i make turns, only slow turns, i get this creaking sound coming from the back of my car...not sure what it is but im thinking swaybar links/swaybar bushings? i want to pinpoint the problem before i start throwing money into parts
Old 07-15-2009, 11:02 PM
94Firehawk161's Avatar
Look at the rear control arm bushings very carefully. Most of these cars have a problem with the rear control arm bushings "sliding" out especially when the car has a decent amount of miles or is used for hard cornering. If this is the case, the sleeve for the bushings will be up against the mount for the control arm (usually on the frame side) and will be making metal-on-metal contact.
Old 07-16-2009, 05:16 AM
shutzero's Avatar
I put in new rear lcas and relo brackets about 15k miles ago
Old 07-16-2009, 12:30 PM
shutzero's Avatar
anyone else?
Old 07-16-2009, 02:01 PM
hitmanws6's Avatar
the springs?
Old 07-16-2009, 02:15 PM
shutzero's Avatar
How would I check if it's the springs or the rear sway bar links
Old 07-16-2009, 03:21 PM
cnd99hawk's Avatar
I would check your bushings, I had a baddd creak in the front, noticed that the sway bar bushings needed replacing - replaced, creak gone!
Old 07-16-2009, 03:44 PM
Are the LCA's greaseable? Are the sway bar "frame" bushings factory, dry-rotted or distorted?
Old 07-16-2009, 05:26 PM
subarubill96's Avatar
^ im with this guy
on my old camaro i had tubular LCA's that were bone dry when i got the car, so greasing that and lubing up / changing bushings on my rear sways cured 99% of the noise coming from the back end of the car
Old 07-16-2009, 07:09 PM
shutzero's Avatar
the lcas are greaseable and i grease them every spring. like i said in the original post i think it has somehting to do with the sway bar links/sway bar bushings so i guess ill start with the bushings and go from there!
Old 07-16-2009, 07:16 PM
shutzero's Avatar
if i go with polyurethane bushings for the rear what size do i need to get? i see someone on ebay selling them with 23mm and 24mm...not sure what to get
Old 07-17-2009, 03:28 PM
Dal1as's Avatar
Grease the D bushings on your rear swaybar. Likely the problem.
Old 07-17-2009, 07:26 PM
shutzero's Avatar
There are grease fittings on those? Or just spray them with silicone
Old 07-20-2009, 04:40 PM
Dal1as's Avatar
You have to loosen the metal clamsp. Take the D bushings out, clean em up, use some marine grade grease or any decent grease on them and put them back in. Pretty easy to do and should be done every year or two, front and back.
