A.C. blows to feet only
Old 07-29-2009, 04:30 PM
maxgee's Avatar
Default A.C. blows to feet only
I just swapped in an ls2 all is good, except after pumping in r134 my a.c. is cold, but only blows thru bottom foot vents.
What area can I check to figure out how to correct the problem?
Old 07-29-2009, 04:32 PM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
sounds like you left off the vacuum line that is responsible for changing it. Small plastic tube with a rubber end that comes out of the wiring on the passenger side, it hooks to the back of the intake on a nipple pointing towards the passenger side. It's REALLY easy to accidentally break that line.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 07-29-2009, 04:34 PM
maxgee's Avatar
Thanks!!
Old 07-29-2009, 05:20 PM
white2001formula's Avatar
Beat me to it! I had the same issue when I did my Heads/Cam. I actually had it coming out the floorboard and the defrost area on all settings.
Old 07-30-2009, 03:56 PM
maxgee's Avatar
fixed!
thanks again
