Not a chev but i need help on the work truck
Old 08-06-2009, 09:47 AM
ruquick02ls1's Avatar
Default Not a chev but i need help on the work truck
This is for my work truck, 1995 dodge 2500 with a 5.9L 360.
NEW
Plugs
wires
cap
rotor
TPS
CLEANED
TB
IAC
Runs rough and has no power, the warmer it gets the worse it runs. Burned a 1/4 of fuel in 30miles. No check engine light, does come on when I turn key on. Checked for codes anyway and no codes.
Thanks for any help.
Old 08-06-2009, 10:44 AM
91RS383's Avatar
O2 sensors?
On a 1995 you do not have downstream O2s so you will not throw a code for an O2 sensor that is bad, but functioning.
Next up is a clogged cat. Look for signs of overheating. Is the cat bright red when you first park, is it discolored, does it rattle? A bright red cat is caused by too much unburnt fuel or a worn out catalyst.
Also check for bad, dirty or stuck injectors.
Old 08-06-2009, 11:00 AM
Originally Posted by 91RS383
O2 sensors?
Thanks for the reply.
I was thinking the same thing but wasn't sure. Now that you mention it, it does run a lot hotter than it use too. I will have to check out the cat and see if it is bright red or discolored or rattles.
Old 08-06-2009, 12:47 PM
I unplugged the o2 sensor and it ran the same.
Old 08-06-2009, 01:51 PM
I replaced the o2 sensor and it runs a little bit better but still something is wrong.
Old 08-06-2009, 01:57 PM
LS14EVR's Avatar
I can't remember exactly, but isn't there more than one o2 sensor? Like upstream and downstream? It's been a while since I had an 360.
Old 08-06-2009, 02:01 PM
LS6427's Avatar
Bad 02 sensors will make it run very rich and stumble and lose power.
If it started all of a sudden though:
You may have one or more fuel injectors that are leaking or maybe the atomizer screen has worn out or popped a hole and a shitload of fuel is dumping into one of more cylinders. That would explain the bad gas mileage.
I've seen this a few times. I think one was actually a Dodge Hemi truck. He lost a ton of gas in a very short time too. It was just spraying like a hose into one cylinder. He found it, replaced it and it was fixed.
Old 08-06-2009, 02:04 PM
only one before the converter.
Old 08-06-2009, 02:43 PM
91RS383's Avatar
I'd say fuel injector now as well.
