low idle help!
Old 08-12-2009, 10:45 PM
383camaroz28's Avatar
Default low idle help!
hey my friends car idles at 500 used to idle at between 500-1000.. my question is what could cause a low idle?
Old 08-12-2009, 11:09 PM
LS6427's Avatar
dirty fuel filter, injectors, fouled plugs, bad IAC valve, dirty MAF....
Old 08-12-2009, 11:49 PM
plugs have less then 5k on them, injectors r out of a 01 SS so ill swap my stocks in an see wat happens, fuel fiter never been changed(145k miles) whats IAC? an maf ill look at
Old 08-12-2009, 11:57 PM
LS6427's Avatar
Considering that its good to change the fuel filter every 10,000-15,000 miles just because they are so damn cheap and easy to change.....I think at 145,000 miles...you're ready
Idle Air Control (IAC)
Spray the **** outta the MAF with MAF cleaner.
But dude....I think its the filter. I would do that first, it'll take you 5 minutes to change and its like $15.00.
Then mess with the injectors.
Old 08-13-2009, 12:03 AM
waterbug1999's Avatar
So, your going to swap out a set of stock injectors for another set of stock injectors?
Old 08-13-2009, 12:10 AM
yeah why not lol he does have money to get 36s or 42s so i have a set for him to see if it is them no bigie,
if i take the fuel filter off gas gonna go everywhere ? lol never changed one before so 2marro is its day
Old 08-13-2009, 12:34 AM
Stock is not a 36 or a 42... You think nothing is going to happen if you just put those bigger injectors in, and dont change your IFR (Injector flow rate) table?
Old 08-13-2009, 12:40 AM
LS6427's Avatar
Just put an oil catch pan under it or one towel. I just let whatever gas comes out go right on the driveway. Every time I've changed one all 11+ years I literally get a little dribble, like maybe enough to fill a shot glass.
Just do it.
Changing injectors is ridiculous..before trying a simple fuel filter.
Old 08-13-2009, 01:23 AM
thanks ls6 alway helpful
Old 08-13-2009, 07:43 PM
STREET99's Avatar
Here are 2ways to change it. I have the same problem with High Idle Code P0507 and gonna try replacing my fuel filter also.
This website is great for step by step how to's:
http://www.installuniversity.com/ins...sity/index.htm
