Shift Boot?
Shift Boot?
So the clips are broken on my shift boot. I've been thinking of a glue or sealant of some sort to get it back on the center counsel. Would some RTV work? Or just some crazy glue?
https://ls1tech.com/forums/appearanc...boot-clip.html
....looks like it's been a while but you could probably pm the guy...
Save the manuals!
I had the same problem and fixed it perfectly. You just need ABS (pipe) cement. (The plastic is ABS.) Mine broke at a bend in the plastic, so I reinforced the weld with a piece of paper clip and we're still going strong.
The cement can be had in the plumbing department of some hardware stores or from a plumbing supply. (Its cheap also!) Its sold right by the PVC cement and pipe primers. In the midwest, I've seen the stuff at Ace, Menard's, and at industrial plumbing/HVAC/MRO stores.
Save the manuals!
If you use the ABS cement, you'll want to let it dry for at least 2 days before installing. (so it can build up strength in the weld)
Save the manuals!
P/N 10306417. GM shows it only as an assembly. $40-75 depending on the dealer.
I normally buy new parts when trim brakes, except for this one. The ring isn't designed well, so I went with the $3 glue and reinforced the problem point. I figured that if I put in a new ring, it would just break again.
