my car SHAKES
Old 10-09-2009, 11:09 PM
mlbz28's Avatar
Default my car SHAKES
Alright heres the deal, I was recently sideswipped on the right side of my '02 Z and now my car shakes at around 60-65 and it gets worse as i go faster.(my passanger seat looks like its having a seizure!) i had bad front tires and thought that may have been the problem so i got new tires but it still shakes. any ideas?! my mechanic said it was my struts but he looked at how my front tires were losing tread and made that determination. but i bought these wheels and tires from someone else so they were worn dwn by them. anything? Thanks guys!
Old 10-09-2009, 11:27 PM
luigiandme's Avatar
Where the wheels damaged or hit?
Old 10-09-2009, 11:31 PM
Slvr00Bird's Avatar
Pics of the damage? The guy you speak of was looking at your tread wear and telling that you were out of alignment.. Would definitely get a professional, state of the art digital alignment and take it from there.. Also may want to make sure pinion angle wasn't messed with (depending on how hard you were hit), as well as the tires all still have their weights and are balanced.. Wouldn't think that those would cause your seat to have "seizures," but all things I would look at.
Old 10-09-2009, 11:46 PM
twelver12's Avatar
well your car doesn have struts so rule that out
alignment angles will wear tires but wont cause a shake like that
your wheels are either horribly unbalanced or bent which would both cause that shake
Old 10-10-2009, 12:00 AM
luigiandme's Avatar
Get an alignment if you havent gotten one in the past 12k miles... and get all 4 wheels balanced..
Old 10-10-2009, 05:48 AM
hitmanws6's Avatar
im willing to bet its your tie rods on that side, wheels wont cause that bad of a vibration even if they were unbalanced
Old 10-10-2009, 04:55 PM
mlbz28's Avatar
if i find the USB connection for my phone ill post some. and i was almost stopped because i was turning into a steep slope, the guy was goin 35. and ill take a look at it though
na the wheels werent damaged
i just got new tires on the front and they were balanced. and my wheels just had the usual wear and tear of the Houston heat
aight ill take a look at that
