Windows Pop/Click while going up
Hey all:
I have had this problem with my windows making a popping noise while going up. The drivers side does it 2 inches below fully up, and the passenger side does it when it goes fully up. I tried adjusting the windows from the tutorial on shbox.com, but it doesn't seem to help. It only happens when I put the window all the way down.
It was annoying, but I havent done anything about it for 3 years. My driver's side window motor is going out, so I opened the door up to look for things to replace. I would like to stop this Popping noise. Its not the gears, I checked to see if they were stripped. It seems to come from the up/down track towards the rear of the car.
I also found a broken rivet in the door, and I couldnt figure out where it came from. (Will I need a new regulator?)
Anyone had similar issues? Any solution?
Well, I am glad I am not alone. Anyone with a solution? It seems to come from the rear Up/ Down channel on both my windows. Maybe it is where the channel is connected to the jack-studs that control the inward/outward adjustment of the top of the window. I couldnt find anything loose!
Yeah this is a sub-optimal aspect of the car - seems these doors/windows just weren't that well designed. Anyway, I had both motors/regulators replaced by a dealership while the tranny was in for replacement and they came back working strong but: my driver's side makes any number of odd sounds, I never know exactly what to expect on any given day: pops, clicks, pings, scrapes, sometimes it's perfectly quiet and smooth, sometimes it sounds like the window is going to crack. What I'm looking at right now is the weather stripping assembly along the lower outside. It's loose, sometimes the end towards the rear moves up out of position and I have to push it back down - positioning and behavior seem connected with the problem, when it's snugged down securely and doesn't move there are less noises. I haven't taken it all the way out but it looks like it has some clips on it, maybe they're worn or bent out of shape from multiple prior motor replacement exercises.
Save the manuals!
Lots of people have this issue. Its usually related to a replacement motor being bolted to the regulator and the bolts coming loose. (There's something to be said for the original rivets!)
Check your motor to regulator connections or regulator to door connections and you'll probably find a loose bolt. This allows one of the three parts to separate (door, regulator, motor) to separate and grind/pop.
The rivets that hold the regulator in.... thats a different story. They have plenty of play. Not what I would call a quality job on GM's side.
Maybe I will drill out the regulator rivets and pop in some heavy duty bolts :hmm:
Save the manuals!
If you still get the pop, you should be able to see where the problem is with the door panel off. Watch the regulator rivets. If they stay put during the pop - they are fine.
Often, the pop comes from the motor gear slipping against the regulator gear. Can you get a mirror in the door and see if the gears are engaged fully?
I park in an underground parkade and have partially solved the window problem by getting a remote gate control so I can get get in and out without opening the window every single time to reach out and punch in a entry code... this reduces the number of window cycles by 98% during the rainy season here in Vancouver which runs October thru May... The more I live with it though the more I think a lot of the problem is related to the weatherstripping which seems to play a role in keeping the window aligned properly while in motion, I'll probably order a replacement and see how that works.
Moderator
it is the window regulator, i had this problem on my car years ago and the dealer replaced the window regulator, i actually have a extra brand new GM one, i can get the part number and see what side it is for if you need one i will hook ya up with a good price on it, mine has been fine for years...pm me if interested
Save the manuals!
Changing the adjustment of the rear track that runs up and down, should change how the window moves left and right. (looking at the door) Did you change the adjustment of the two metal brackets with felt pads that are bolted to the top of the door? These impact who the glass moves in and out and can cause this binding.
