Blinkers, Reverse lights dont work
well i guess i have to start out with saying that my car was a manual and i swapped out the tranny for an auto. All the lights use to work fine before the swap, now the blinkers and reverse light dont work. I already checked all the bulbs and they are good, what could be causing this?
well heres something to try...i went out this morn (mine was doin the same thing yours is doin) and everytime i would replace the fuse it would just blow again in like 2 or 3 minutes...well when i unplug the reverse switch its fine,,,it doesnt blow so it must be something in there(or atleast on mine)...hope this all helps man..
its something to do with these fuses/wires....cause that fuse controls your backup light, running lights, and blinkers....and no i just swapped trannys in general....went from a t56 to a NEW t56...
sorry for the ignorant questions, i am by no means even a beginner at this. SO IN IDIOT TERMS...behind the fuse panel, i should find a brown wire, check it for 12v with ignition in the ON position, is this correct??
