oil in radiator!!!
oil in radiator!!!
Just checked my radiator fluid yesterday in my 98 SS and its milky and slimy. Ive been losing fluid for a lil while but didnt know where it was going. There is no antifreeze in the oil. So im thinking its a head or manifold gasket??? anyone have this problem? my car has 85,200 miles
Leaking power steering fluid cooler (if you have one) = black **** in the radiator floating around in the radiator
Leaking tranny cooler in the radiator =black **** floating around in the radiator
I've never seen or heard of milky white colored stuff in a radiator.......................
Its a 6 speed car. The fluid in the radiator is more like a pea soup/mustard color. I just changed the tranny fluid and put royal purple about 2 months ago...could be related. Also, i did have a small radiator leak between the throttle body spacer and intake but nothing serious. I did notice the power steering pump has been using alot of fluid, so i will check that out as well. Thanks.
it does look like really old fluid but its not. there has been a radiator low light on my dash for awhile i cant get it to go off even tho i have been fillling it up. i add water to once every two weeks or so, so i had a feeling somthing was gonna go wrong then found out it was all nasty. i gotta work today and write a paper after so tomorrow i will drain the radiator and follow all the hoses from tranny, power steering, and coolers.thanks for ur guys help and i will keep this updated.
If you DON'T have the factory power steering fluid cooler...it can't get into the coolant either. Look at the picture below, thats a factory power steering fluid cooler. Its the metal pipe in the upper radiator hose. If you have it....and you are losing power steering fluid and have no external leaks or puddles on the ground, its bad and probably leaking into your coolant. Get rid of it, do not replace it.
I had the same milky substance in my radiator.
Kept losing coolant too. Pulled my heads and cracked #2 sleeve
Not saying thats your case, but I had oil in the rad and no water in the oil.
im having this EXACT problem word for word, mines an 02 ws6 m6, i drained the reservoir and there was black **** in it looked like oil, but when i drained the radiator it was just milky white, power steering fluid level goes down fast too
Save the manuals!
The coolant reservoir is a good tattle tale for the problem. If your coolant is old, it could be oxidized coolant - or it could be the PS cooler issue.
If you have alien-looking slime all over your coolant dipstick that won't come off, its probably PS fluid. Your PS fluid levels will also be dropping. You'll want to confirm this first as the PS cooler problem will require a coolant flush. (Don't want to flush and then find its a PS problem and have to flush again.)
Post pics!
Post pics!
Its almost a 100% certainty that your PS fluid cooler is leaking into the coolant. Mine started leaking late last year.
Its a total piece of **** design by the idiots at GM. It actually makes the PS fluid HOTTER, it IS NOT a cooler. Maybe if you took the car out on a road course for 1 hour straight and beat the living crap out of it, then it might get so hot that 220 degree radiator coolant will help it cool down, but then it will also be making your coolant hotter. Perhaps the dumbest design ever by the ***** at GM.
All you need to do is take the PS fluid cooler off and look inside it, wipe your finger or a rag inside that pipe...if its coated with black ****.....its bad. Yo're entire engine and radiator will have this coating throughout......it needs a very good flush.
A regular flush using the factory petcock drain valve will NOT be sufficient.....
I will give you a write up I did to remove it and install an aftermarket cooler for about $40.00 and 30 minutes of your time with just a philips screwdriver and a razor blade.
Then I'll tell you how to flush every bit of that crap out. That stuff gets caught inside the engine block and its not easy to get out.
Here's pics of my PS fluid cooler....it never gets more than warm to the touch. The factory cooler will give you 3rd degree burns if you touch it.
Cheesy system says my photos exceed forum limits....I've posted these exact pics several times
FOUND THIS:
Post #5 in this thread will tell you everything about an aftermarket cooler install. EASY!!!!
https://ls1tech.com/forums/automatic...g+fluid+cooler
FOUND THIS:
FOUND THIS:
Is this the cooler you used?
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_TRANSMISSION-COOLER-Imperial_6014720-P_895_R|GRPCOOLAMS_555599089___
edit: oops, I thought you were the OP. Oh well, I'll leave this all here.
Then just get the full upper radiator hose and some clamps. Get enough PS fluid so you can flush all the old out because when your cooling system cools down after engine shutdown, the pressure rises a bit and surely coolant has been blown back into your PS fluid.
You don't need to get that 3/8" hose if your PS lines are perfect, I just wanted to replace the line from the bottom of the PS fluid reservoir.
But check that pipe to make sure there's black PS fluid residue inside the pipe.
so today i drained my radiator fluid from the plug at the botom of the radiator. To my surprise it was super clean and bright orange. so i took the hoses off the ps cooler and the alien looking slime was inside that pipe. i then redrained the radiator and more of the slime came through that plug...so hopefully its that metal pipe leaking and not a head gasket. so this weekend im gonna replace the hose, power steering lines and i wanna get that other cooler cuz im sure a new factory ps cooler is a **** load of money. So a transmission cooler will work as a ps cooler in place of the factory metal pipe version correct???
