No code
Old 01-24-2010, 10:59 PM
pick1923's Avatar
Default No code
I have a 58 pu with a 2004 vortec. Ive driven this truck for a couple years with no problems. The other day I had a problem at idle. After running hard, it has rough idle and sputters off of idle. If I drive it easy for a short distance it smooths out. I changed the o2 sensors with no change. computer is not giving me a code. Any ideas? Thanks Mark
Old 01-24-2010, 11:14 PM
conan's Avatar
Have you tried cleaning the MAF ?
Old 01-24-2010, 11:20 PM
pick1923's Avatar
I drove in some heavy rain when the problem started thats why I changed the o2 sensors. I thought maybe they got submerged. I'll try cleaning the maf. Wouldn't that throw a code? Thanks Mark
Old 01-24-2010, 11:31 PM
pick1923's Avatar
Maf is clean
Old 01-25-2010, 12:08 AM
99huggerorangeZ's Avatar
possible intake gasket
Old 01-27-2010, 08:20 PM
pick1923's Avatar
Got any ideas on how to check it without removing it. Thanks Mark
Old 01-27-2010, 11:19 PM
spray throttle body cleaner around the sealing surface between the intake and the heads,also spray around tb gasket flange.
Old 01-30-2010, 07:17 PM
pick1923's Avatar
I pulled the MAF and cleaned it, checked for vacuum leaks from air cleaner to the head and no luck. Same problem, rough idle after hard acceleration. Smooths out after short distance. I think it must be some sort of vacuum leak but it is undetectable so far. Thanks for the ideas, any others would be appreciated. Thanks Mark
Old 01-30-2010, 07:42 PM
Save the manuals!
wssix99's Avatar
Does the problem only happen when the engine is cold? If you idle after driving for a while is everything OK? If you re-start the engine while its still warm, does the problem come back?
