How to change valve springs?
Old 02-09-2010, 08:11 PM
SpecV44's Avatar
Default How to change valve springs?
What is the easiest way to change the valve springs with the engine IN the car? I just bought a 2000 TA, medium sized cam, and after talking to a guy that looked at buying it, I think I would be better off pulling a spring and getting it measured.
Would it be easier to pull the 6 bolts from the subframe, and pick up the car 6" or so?
Old 02-10-2010, 01:25 AM
eseibel67's Avatar
Tim's tool. Search this site.
Old 02-10-2010, 03:36 AM
f-bodyguy's Avatar
if your just puling one do the driverside front and if ony one just buy a cheap sping tool fron local parts store
Old 02-10-2010, 08:37 AM
SpecV44's Avatar
I have a tool I made when we did my brother's springs/retainers after he blew up his LS1, but we did that with the subframe/engine out of the car. Im not worried about when I pull just 1 to test it, I am worried about needing to change them how much of a PITA the ones under the cowl are going to be.
Old 02-10-2010, 10:52 PM
fleetmgr's Avatar
The problem with only measuring one of them is that it won't tell you a thing about the other 15.
Old 02-11-2010, 08:02 AM
eseibel67's Avatar
PITA level on changing the rear ones is 2 out of 10. Not real easy, but not real bad either.
Old 02-12-2010, 02:51 PM
The Fugitive's Avatar
check out ls1howto dot com and it will show you plus have tool recommendations.
Old 02-13-2010, 06:30 PM
Squirts11's Avatar
Used it last week. Good/inexpensive tool.
Old 02-13-2010, 07:44 PM
SOMbitch's Avatar
The Crane tool is the Best IMO. Thunder sells a clone IIRC.
Quick Reply: How to change valve springs?
