Brake Grinding Noise on Left Turns
Old 02-10-2010, 11:46 AM
CrazyDrivinJoe's Avatar
Default Brake Grinding Noise on Left Turns
Ok So I spent about 2 days looking at what the possiblities of the problem could be and I am not sure if its the rear end or a simple ebrake tightening. It sounds like the squealing of metal to metal on the brakes and the discs look fine. My ebrake lever pulls way up so I am pretty sure it needs to be tightened but I dont think that when turning left the shoes would be loose enough to hit the rotor. Has anyone else had the same noise when turning left.
I also think I have a howl from the same passenger rear tire that could be the wheel bearing. I know this is dumb to not have investigated it first but its been under 30 when I get home from work so I havent felt like freezing my *** off and taking it all apart. I am just looking for some insight for anyone who has heard this sound and how they fixed it.
Old 02-10-2010, 01:52 PM
meangreenchevy's Avatar
my problem was identical and it was a bearing in the rear end i just switched out the rear for another stocker with some better gears the price on labor was way to much the whole rear end needs to come apart
Old 02-10-2010, 01:55 PM
Joshiedoom's Avatar
Whole rear doesnt need to come apart. Just pulling the c-clips. if it is the wheel bearing
Old 02-10-2010, 03:46 PM
Pilsner's Avatar
Could be the e-brake shoe linings came off the shoe.
Old 02-11-2010, 04:38 AM
myk
myk's Avatar
I've got this same issue as well. So, you just pull the c-clips, and then what?
Old 02-11-2010, 07:55 AM
Joshiedoom's Avatar
Slide out the axle and pull out the seal and bearing
Old 02-11-2010, 11:10 AM
Yea axel shafts are not hard to take out I did it in my jeep it would make sense why I have a minor howl from that same area I guess ill buy a bearing and replace it this weekend and hope that fixes it.
Old 02-12-2010, 08:20 AM
I feel dumb for the fact that my problem was what I thought it was which was just brakes the inner pad was down to almost nothing
Old 02-12-2010, 06:07 PM
monte383sbc's Avatar
if the pads were low you could have bin down to the scrapers on the pads
