Starter motor mount on block....broke.....
Old 06-21-2013, 04:27 PM
  #181
Junkman2008's Avatar
Originally Posted by BlackBartZ
01 Z28 with a lot of time and money in the stock bottom end and not so stock top end. I am a nut about properly torqued fasteners on everything i touch because my name is on it. About 14 months ago on a normal cold start it decided to spit the starter out. Starter housing broke then popped the outboard block mount too. Read up on the issue here from the knowledgable and much respected members. Bought a truck starter, torqued the inboard bolt to spec and could only hand tighten the outboard bolt before it would skip. Its been starting without a problem for over a year now and i keep thinking one day im going to fix that. Thanks to the members here for saving my **** in a sense.
Mine did the exact same thing. I put some locktite o it and called it a wrap. I will deal with it on the day I have to pull the engine. I will either go with a new block, a LS3 or that bracket I posted in post #148.
Old 11-14-2013, 09:11 AM
  #182
redcamaro's Avatar
Originally Posted by Junkman2008
I may as well add some new info to this thread that I found. There is a work around for those with a busted block that doesn't require getting the block welded. Someone fabricated a bracket that bolts up to the broken block and make the starter solid as the Rock of Gibraltar. It mounts up to some existing holes on the block and also uses two of the bell housing bolts. Look at the pictures below for more clarity. It's called a starter bridge.
Look at the picture of starter bridge. The hole labeled #2 goes into the block where the broken screw hole is in the picture of my broken block (labeled #2 on the engine picture also). That area will probably have to be grind down so that the bracket is flush against the block to some degree.
Number 3 on the starter bracket goes to hole #1 on the engine block. Number 1 on the starter bracket goes to the bottom of the starter, which aligns with the hole that is busted on my block (labeled #2 on the engine picture).
Holes #4 & #5 on the starter bracket will go where the two, bottom bell housing bolts are on the engine. You'll remove those two bolts and use them as two of the starter bracket mounting screws.
So that's how it mounts. Now here's the kicker. The guy wants $370 for the bracket. That price is smokin' crack. He did have it listed for $350 but he has since raised the price. Here's his site. I only paid $220 to have mine welded bck together and the guy who welded it guaranteed it for life.
Here's a picture of it in place.
Here is the bracket I built. Works like a champ. $10.00 worth of iron and a little time.
Attached Thumbnails Starter motor mount on block....broke.....-img_0392-1-.jpg   Starter motor mount on block....broke.....-img_0393-1-.jpg
Old 11-14-2013, 11:18 AM
  #183
blackbirdls1's Avatar
is this problem that common? I have never really heard of this happening
Old 11-14-2013, 11:27 AM
  #184
I only see 2 mounting holes. How does it mount?
Yes, it happens on occasion.
Old 11-14-2013, 11:36 AM
  #185
Greattt, lol. I guess this can be avoided.
Old 11-14-2013, 01:03 PM
  #186
Yes, by getting the correct starter.
Old 05-05-2014, 02:32 PM
  #187
stngh8r's Avatar
Smile
Add my name to the victim list.
The piece of my block is MIA. So, a friend of mine (britt2020) is going to try and help me make a bracket similar to the one their asking $370 for. I could easily see spending over $100 for such bracket, but $370 is a bit ridiculous.
Old 05-06-2014, 02:38 AM
  #188
Originally Posted by stngh8r
... I could easily see spending over $100 for such bracket, but $370 is a bit ridiculous.
I agree big time. Post whatever you come up with. I'd like to see it.
Old 05-06-2014, 06:38 PM
  #189
LS6427's Avatar
Or just have someone fill that area with weld in that whole area, drill a new bolt hole and tap it. That bolt isn't the one with all the stress, it just keeps the starter mounted and in place.
It will hold forever.
Old 05-06-2014, 10:00 PM
  #190
TA_Freak's Avatar
Just ran across this thread this morning and finished it just now. With 265,000 miles, original starter and some paranoia, I just ordered another starter with the housing for two long bolts.
Old 05-06-2014, 10:03 PM
  #191
I envy you. I wish I had seen this info before I busted my block.
Old 05-07-2014, 09:37 AM
  #192
TA_Freak's Avatar
damn ... I feel bad that you (and others) had to go through this. Where do you stand with your block now?
Old 05-07-2014, 09:47 AM
  #193
Oh, I had mine MIG welded back together again. Runs like a champ.
Old 05-16-2014, 10:32 PM
  #194
Super Hulk Smash
JakeFusion's Avatar
I just ordered the 6492SN from Amazon. I don't want this happening!!!
Old 07-02-2014, 07:11 PM
  #195
chevybayboy's Avatar
Default very nice piece
I broke the ear of my block just like many others. Damn what to do looked up the stater bridge Was going to order it come to find out were in the same city. Give him a buzz asked question s very nice a good customer service. So I order one up he finish in a few days I go meet with him at his shop. He shows me how it works how to put it on comes with the bolts and it's very sterdy is it worth it? Gotta ask yourself buy a new block get it welded which might not work.. so 375 for my new motor Hell Yea it's worth it.
Old 07-02-2014, 10:14 PM
  #196
RockinWs6's Avatar
Did Micore weld that for you?
Old 07-02-2014, 10:25 PM
  #197
Majestic9C1's Avatar
just changed out my starter yesterday to a New Delco Remy #96232
works like a charm.. its smaller (gear reduction) and has the two long bolts..
Old 01-17-2016, 02:45 PM
  #198
Black Giddyup's Avatar
Default Starter and starter bridge for Sale
I bought a AC Delco starter from a local shop and starter bridge from 2nd sucks racing to resolve the broken starter mount on the engine block of my 2002 Z28. Despite installing the beefier starter and the starter bridge it turns out the engine seized. I didn't get to the repair right away and the shops I bought the starter and starter bridge from would not allow me to return the parts. I ended up selling the car to a guy that dropped in a cast iron engine so he didn't need the parts.
I have a brand new AC Delco starter (model 337-1027) and the starter bridge that I would like to sell. I'm asking $140 for the starter (retails for around $180) and $300 for the starter bridge (retails for $370). Details for the two items can be found at the links below.
Starter
http://www.oreillyauto.com/site/c/de...920&ppt=C0330#
Starter Bridge
http://2ndsucksracing.weebly.com/web-store.html
If you are interested in buying either the starter or the starter mount please let me know.
Attached Thumbnails Starter motor mount on block....broke.....-337-1027-starter-motor-2.jpg   Starter motor mount on block....broke.....-starter-bridge.jpg
Old 01-17-2016, 05:45 PM
  #199
I was hoping that you were going to sell that starter bridge for cheaper, although I know exactly what they cost.
Old 01-19-2016, 02:06 PM
  #200
stngh8r's Avatar
My buddy Britt2020 made a brace for me. So far so good, been on for ~5k miles.
