replaced the window motor now WTF!?
ok so i did everything right motor is working like a dream i put everything back then.....the damn window doesn't seal with the weatherstrip now i know there are adjustments that can be made i went to shbox.com and it was all explained well but the part that wont seal is the bottom rear section drivers side i adjusted the window up top and pulled the glass back but still there's a gap only there any input appreciated!
maybe the second option gonna take it apart tomorrow if it doesn't rain BTW there's no way to adjust the door itself right? if i could move it just a bit i'm sure it would seal!
Save the manuals!
Yea, you have to take the panel off. That short inner channel (If I recall correctly, its attached with two bolts.) controls the level of the window as it goes up. Adjust it one way and the rear of the window will lower relative to the front and adjust it the other way and the opposite happens.
