Squeaking coming from the front of the car
Old 05-03-2010, 05:05 PM
Jpmilan's Avatar
Default Squeaking coming from the front of the car
So I just recently got my trans am and I have a problem with it =/ I keep hearing a squeaking noise in the front of the car kinda by the tires. It only makes the noise when I'm at low speeds or when i go over a bump or go in and out of my drive way. Nothing seems to be wrong with it and while driving home today on the highway, I gunned it and the car was running perfectly smooth. There are no issues with the cars performance in anyway it just keeps making this sound and I'm wondering what it could be? Any ideas?
Old 05-03-2010, 05:19 PM
ROCNDAV's Avatar
Sway bar bushings? you should be able to unbolt them and grease them up by hand.
Old 05-03-2010, 05:21 PM
Jpmilan's Avatar
i hope it's something as simple as that, but like i said the car still runs perfectly fine. I'm taking it in to a family friend's shop tomorrow just to get it checked out to let me know for sure, just wanted to get some opinions before hand so i could rest a little easy.
Old 05-03-2010, 05:24 PM
ROCNDAV's Avatar
Is it constant or does it only squeak when going over bumps/dips?
Old 05-03-2010, 05:34 PM
Jpmilan's Avatar
only bumps and dips and at lower speeds occasionally.
Old 05-03-2010, 05:37 PM
ROCNDAV's Avatar
Yeah, that sounds like the front sway bar bushings to me.
Old 05-03-2010, 07:41 PM
Jpmilan's Avatar
Alright so I just went driving with my dad so he could hear it himself. Going out we didn't hear a sound, but then coming back it started making it again. When we got out of the car we popped the hood to see if anything looked abnormal but everything is perfectly fine looking. He began pushing down on the car over and over and it kept on making that squeaking noise every time it bounced. Exactly like how an old recliner does whenever you sit down in it and get up, it makes that annoying bouncing sound.
Old 06-07-2010, 11:06 AM
mile_high51's Avatar
I have the same problem, I will be checking and greasing up the sway bar bushing before the weekend and see what that does and keep you posted op
btw, it really is annoying and bothers that crap out of me. so i know where your coming from.
Old 06-07-2010, 09:48 PM
fleetmgr's Avatar
If you have stock rubber bushings, then no grease is necessary. If you have replacement urethane bushings then that could be the cause. If you have lots of miles on the car, I'd suspect bad control arm bushings.
Old 06-08-2010, 07:02 AM
jam01's Avatar
check the sway bar end links too. they make an annoying noise when bad, sounds like a rattle or loose bolt.
Old 06-08-2010, 12:54 PM
ill check all that out. its a really loud high pitched rattle, not really a squeaking. right now i only here it on the passenger front.
its the worst. especially cruising slow through on like main street, it really echoes off the brick buildings and parked cars. i hate it.
