Abs inop + brake
Old 05-20-2010, 11:42 PM
Reaperchild's Avatar
Exclamation Abs inop + brake
ok so im gonna mention all the mods done lately
AIR PUMP REMOVED
CRUISE CONTROL CLUTCH PEDAL SWITCH FIXED
THERE ARE SOUNDS IN MY FRONT WHEELS .. probably the LT1 rims dont like the ls1 brake calibers.... the ABS INOP + BRAKE LIGHT SHOWS AFTER DRIVING FOR A WHILE & STAYS ON TILL CAR IS DEAD !! .... low traction never showed up on my cluster till i did the cruise control switch fix & air pump removal ....
any usefull input is appreciated
Old 05-21-2010, 12:52 PM
Drew24's Avatar
Check that ground for the abs mine did that accept they would flash on and off. The gound will be on the passenger side right by the fender.
Old 05-28-2010, 05:16 AM
i just swapped wheels & tires ... i had 255/ 55/17 all 4 ..... now 295/45/18 rear with 245/40/17 front ... my basic tune involved a 373 ratio also ... a freind mentioned a relationship between those & a tune requirement .... i think my speedo gauge is off too ... i feel like driving 80 mph while speedo reads 65 mph !!
any input apreciated ...
note that this issue came on only when i fixed the cruise control clutch pedal switch .... !!
Old 06-06-2010, 11:58 AM
back to zero .. got my tire tuned out last nigh ... still ABS INOP+BRAKE LIGHT will come on after two miniutes of driving ... now WHAT MAY BE THE CAUSES OF THIS ?? i hate having light's on my cluster (WARNING)
Old 06-06-2010, 09:35 PM
Spartan7's Avatar
Did you do that? I had the same issue, and it was that bad ground.
Old 06-16-2010, 10:11 PM
help please .. Noticed that they also come on if i hit the break during cruise
Old 06-19-2010, 02:21 PM
LT1TA's Avatar
both are on in my car, brand new brakes, i am sure with my car its the rear end. I have a 3 channel rear and i need a 4. So have you changed rear ends or something before?
Old 06-21-2010, 04:35 AM
i lost u on the 3 & 4 channel part. i got all the stock crap with 373z ring & pinion .. please do input more about ur channel theorey
Old 06-21-2010, 05:54 AM
SS4Luck's Avatar
i cant beleive someone didnt catch that before. You ahve two completely different size tires on your car, and they are ******* with your computer. Your brakes and grounds are fine, the PCM is seeing 2 wheels traveling at one speed and 2 traveling at the other (revolutions per mile speed). Your rear tires are 29" tall and your fronts are 25". That is a retarded difference and what is causing it. **** how the hell did you get a 295/45/18 to fit?! my 295/45/17s rub a **** ton i can only imagine if they were on 18s
post pictures. I bet you $100 that if you put 4 matching size tires on the car the speedo would be off but the abs and brake like would turn off too
Old 06-23-2010, 11:21 PM
Question thanx for your input ... so your suggestion is to ge a 55 on the front 17z ??
your suggestion is to get 55 on the front 17z?
