AC Belt Replacement.
Being that its been over 90 for damn near a month now, I'm going to have to suffer through the heat and agitation of replacing the AC belt that broke on my car last Fall. From my understanding the airbox assembly and main drive belt have to come off then the AC belt is relatively easy to get to. However, I don't have any jack-stands (let alone an air conditioned lit garage to do this in), is there anyway to replace the belt from up top?
Thanks for any help.
No need to remove the air box....or even touch it, or even get close to it.......lol
Simply loosen the main belt.....30 seconds to do that.
Jack it up.....3-5 minutes.
Move the main serpentine belt off the crank pulley. Slip the new A/C belt into place. Put a ratchet on the lower tensioner and rotate it like you are trying to loosen the nut and it will move the tensioner so you can slip the belt into place. Let the tensioner go and the belt is on........1 minute.
Put the serpentine belt back on......30 seconds.
Its literally a 5-8 minute job with just a ratchet.
Go for a cool drive.........
I would be quite interested to see someone do that from the top.....
