A/C chattering when turned off
Alright guys, one of the many weird noises my car makes is a chatter from the A/C compressor when it is turned off. Yes, it's noisy when it's OFF.
When I turn the A/C on the noise immediately goes away and it blows nice and cold.
I'm thinking it might be a clutch or bearing in the compressor? Anyone else have this problem?
Car has 53k miles and I have not fiddled around with the A/C at all.
I had a scraping noise with it off. The plate was scraping on the pulley. I used a puller to pull the clutch plate off. It wasn't worn so I sanded the plate and face of the pulley to get off any rust, sprayed it off with brake cleaner, and pressed it on with a wider air gap. I think spec is .020 to .030. I set it at .030 or maybe a touch over. Clutch still engages and scraping is gone, so all is good for now. My car has really low miles and I think rust builds up when they sit. Just something to look into.
https://ls1tech.com/forums/general-m...-c-clutch.html
