Help Fix My Noisy A/C Clutch
Just picked up a 02' Z28 A4. The car has been very well maintained but it had been sitting for almost a year before I bought it.
When the A/C is *off*, there is constant noise coming from the compressor clutch. I guess you could say it almost sounds like a hiss. The sound goes away immediately after I turn on the A/C and of course the sound returns when I turn the A/C off.
I'm not familiar with the operation of the clutch, could I damage anything by simply spraying some lubricant right into the front of the clutch?
You won't hurt anything, but you won't help anything either. That's a sealed bearing, so the spray lube won't get where you want it...all you'll do is make a mess. Time for a new clutch.
Yep, bout the only other thing that might work is to get a puller and give the clutch a little more air gap so it doesnt make contact when not engaged. not very much or the magnet wont pull the clutch in. The best fix though is a new clutch.
I see they sell just the clutch bearing. Is that most likely the culprit? Bearing in mind that it only makes noise when it's not engaged and is silent when it is engaged. Thank you for the help.
If you'll look at the pulley/clutch assembly with the engine running, A/C off and then again with the A/C on, you'll see what I'm talking about.
I have the exact same problem, and I've just been putting off repairing it. How hard is it to actually replace that bearing? You have to pull the clutch, no? Do you need a puller to get the clutch off?
Thank you! I have the same issue and it's very annoying.
Can someone post how to do the replacement? I looked at the ac compressor and it looks like theres no bolts or anything on the face to get the pulley off.
There's a nut holding it on. You'll need something to hold it while you turn the nut.
Also looking for a response to this. Will I need to rent any tools to do this job myself?
Thank you for all the fast replies! I have access to a lot of tools, just wondering if I needed any specialty tools to pull/press the bearing on. Thanks for clearing that up.
I will attempt this fix this weekend and I'll see if I can snap a few pics.
it has been awhile since i looked at the compressor on my t/a, but most gm compressors need a special puller to remove and install the clutch. there is a nut, but the clutch is still pressed on.
check to make sure your a/c belt tensioner and idler pulley are ok, i was having the same issue with my car,it sits most of the time. anyway it ended up being the a/c belt tensioner and idler pulley and i threw on a belt for good measure-NOISE GONE
If it's anything like the one on my ford truck, i used a pry bar to get it off, and you should be able to lightly tap the new one back into place. dont just replace the bearing cause you will have a hell of a time getting it out of there.
