stupid question
Old 08-22-2010, 05:30 PM
Jpmilan's Avatar
Unhappy stupid question
So this is a pretty obvious question, but I just wanted to check. The other day my brake lights went out, but the light on the spoiler still works. However, my hazards and signals still work. I'm thinking that it's probably due to my brake light switch going out rather than both of my actual brake light bulbs blowing correct?
Old 08-22-2010, 05:37 PM
eseibel67's Avatar
Signal wire for high mounted brake light runs separate after the brake switch. Problem could be in your turn signal switch, or the wiring.
There is NO chance you burned out 4 brake light bulbs at once.
Old 08-22-2010, 06:04 PM
Jpmilan's Avatar
alright that's what I was thinking about the bulbs. So another stupid question, I guess the main brake lights and the spoiler brake light have different components that make them work then?
Old 08-22-2010, 09:59 PM
eseibel67's Avatar
Your brake switch is obviously working if the spoiler brake light comes on. Check the attached picture.
On your turn signal switch on the column, check for 12V at pin "P" (the light blue wire) when the brake is applied. If you have power there, you will need a new turn signal switch.
File Type: pdf
Old 08-22-2010, 10:07 PM
eseibel67's Avatar
Sorry, that pic got cut off. This one is better:
File Type: pdf
Old 08-23-2010, 09:07 AM
zachrywd_01TA's Avatar
additionally check all your bulbs, if one is bad or burned up and can send a ground loop back through the system and it wont operate correctly. replacing a burned up bulb can magically fix other bulbs on the same circuit... sounds crazy, but I've seen it.
Old 08-23-2010, 10:36 AM
eseibel67's Avatar
Hazards work.
Old 08-23-2010, 11:03 AM
Originally Posted by eseibel67
Hazards work.
ah right, i forget i dont drive a grand am anymore
Quick Reply: stupid question
