Does a bad starter throw a code? ... If it does, what code would it be?
Old 12-03-2010, 03:46 PM
WS6 Rampage's Avatar
Location: The dirty taint of the country. ...Los Angeles
Default Does a bad starter throw a code? ... If it does, what code would it be?
Old 12-03-2010, 03:52 PM
99huggerorangeZ's Avatar
A failed starter motor/solenoid will not throw a DTC.
Old 12-03-2010, 04:04 PM
That's what I thought! ... Thanks.
... I have another thread going on in the tunning section and the problems I've already addressed were a p1637 & p1626. ... Actions already taken were bench testing the alternator and battery (both good)... Exctiter Wire from alternator changed. Romoved PCM from the car and had my Tuner turn my VATS "off". ... Now, I'm not throwing any codes but she's still not turning over.
Only thing(s) left to check or try are the starter, starter relay or passkey bypass and big thick battery cable.
.... Good times!
This is "process by elimination" at it's retarded best! ... If anyone can mention a variable that i haven't considered, I'm all ears. ....Opinions?
Old 12-03-2010, 04:19 PM
BTW, I swapped the original starter out about a year and a half ago with a REFERBISHED starter. ... If it's the starter, I'm never buying a refurbished anything ever again!
Old 12-03-2010, 04:27 PM
lt1pwr1's Avatar
Ummm, testing the starter should have been one of the very first things you tested if the car isn't cranking. I would say before sending the PCM out, and bench testing the alternator and battery. Definitely check out the starter. And yes, seeing that you bought a refurb, I would highly suspect that to be the culprit. I don't buy any rebuilt or refurbished garbage because they simply don't last. It's usually not worth it in the long run.
Old 12-03-2010, 08:13 PM
... I know, I know! I feel stupid for not testing it first. ... BUT...
...I bench tested the starter. The small gear would not protrude and engage. .. Bought a new starter. Put it in. ..... CAR STILL WON'T START!!!! ... ... I feel like punting a small child right now!
Old 12-03-2010, 09:14 PM
joecar's Avatar
When you turn the key to start, does your voltmeter drop down to 9V (or so), or does it stay up...?
Old 12-03-2010, 09:38 PM
It stays up near 13. It doesn't drop.
Old 12-03-2010, 09:52 PM
Btw, I plugged in a new starter relay to no avail.
Old 12-03-2010, 09:57 PM
double check your connections at the battery and starter
Old 12-03-2010, 11:03 PM
...What would I be looking for?
Old 12-03-2010, 11:24 PM
loose connections
Old 12-03-2010, 11:56 PM
loose connections
Gotcha. ... It's not going to be that, I guarantee!
...Next!
Old 12-04-2010, 01:08 AM
...Next!
does the starter make any noise at all? you could try and tap on the starter housing and have someone crank it over at the same time.
Old 12-04-2010, 02:30 AM
If your referring to the "*click* *click* *click*" sound, then no. ...
Old 12-04-2010, 04:05 AM
KrisXpc's Avatar
Bad starter solenoid. This is located on the steering column.
Old 12-04-2010, 04:46 PM
starter solenoid isnt located on the steering column its part of the starter assembly. i think you meant ignition switch. i would try what i suggested and have someone tap on the starter with a hammer while you crank it over,might just have a dead spot. worth a shot atleast.
Old 12-04-2010, 07:03 PM
t/a98's Avatar
I had an ignition switch go out and it acted like that, the thin wires cracked over time. I replaced it with one from gm, but could have replaced the wires if your on a budget. It might be worth looking to check for obvious breakages. Maybe eliminating vats makes my suggestion wrong though.. Idk
Old 12-04-2010, 08:47 PM
Well I just had someone try cranking it over while I was under the car. It sounds like the starter is working. Im just not hearing the **click** sound everyone knows and loves. ...
... I'm wondering if there would be any point in doing the passkey bypass if my VATS are tuned out already. .....??? ....
Old 12-04-2010, 09:17 PM
sounds like you have a bad starter armature/solenoid. i would get rid of that refurbished POS or exchange it for another one.
Quick Reply: Does a bad starter throw a code? ... If it does, what code would it be?
