Camaro Curb Weight?
Old 01-05-2011, 01:55 AM
BFarrier's Avatar
Default Camaro Curb Weight?
I have a 2000 Camaro SLP Z28 hardtoop M6 and the curb weight on the door sticker says this car weights....4187lbs.. to me that seems very heavy? is this correct and what can i do to lighten it up alot but still be streetable?
Old 01-05-2011, 02:19 AM
Latch's Avatar
Holy ****, did your car come with a boat anchor as a factory option?
4th gens don't weigh anywhere near 4100 lbs. Most weight in around 3400-3500 lbs depending on options.
Old 01-05-2011, 03:26 AM
flippincamaro's Avatar
you cant go by the door weight, That is with the car with 4 passengers, they usally weigh between 3400-3650 usally
Old 01-05-2011, 05:31 AM
caseypryan's Avatar
I bet your car weighs right around 3400
Old 01-05-2011, 06:40 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Also to add, they include a full gas tank.
Old 01-05-2011, 01:18 PM
BFarrier's Avatar
alright thanks cause i was thinking around 3400 it should be then when i say that i was.. no way this aint right. thanks im going to the dump today and weight it see what this girl weights maybe throw here on a diet after the results...
Old 01-05-2011, 01:45 PM
LS6427's Avatar
The nitrous your planning on doing will trump any amount of weight reduction you can do. Add a small 50 shot and that will out-do any amount of weight reduction you can possibly do.
Old 01-05-2011, 02:14 PM
WS6 Rampage's Avatar
Location: The dirty taint of the country. ...Los Angeles
....Jenny Craig
I just remembered the movie Dodgeball when Ben Stiller told one of his employees
"Add 3 pounds to the women's scales before you leave!"
Old 01-05-2011, 03:58 PM
bad_408_vert's Avatar
My convertible is around 36xx I doubt yours is 4100.
Old 01-05-2011, 04:04 PM
senicalj4579's Avatar
Well from what I can recall an a-4 camaro will weigh in at 3440lbs so your m6 weighs, maybe 50-100lbs less?
Old 01-06-2011, 12:44 PM
BFarrier's Avatar
full tank im at 3500lbs
Old 01-06-2011, 04:05 PM
Save the manuals!
wssix99's Avatar
Maybe the 600 lbs. is all the other emissions equipment required in CA?
Old 01-07-2011, 05:07 AM
sxracerb25's Avatar
A gross vehicle weight rating (GVWR) is the maximum allowable total weight of a road vehicle or trailer when loaded - i.e including the weight of the vehicle itself plus fuel, passengers, cargo, and trailer tongue weight.
The difference between gross weight and curb weight is the total passenger and cargo weight capacity of the vehicle. For example, a pickup truck with a curb weight of 4,500 pounds (2,041 kg) might have a cargo capacity of 2,000 pounds (907 kg), meaning it can have a gross weight of 6,500 pounds (2,948 kg) when fully loaded.
Old 01-07-2011, 07:36 AM
Steve Gunn's Avatar
My no options hardtop model was 3360 with no spare and a half a tank stock. I'm told you subtract 750 or 850 for cargo from your gross. Find a truck scale.
Old 01-07-2011, 09:07 AM
Texhotrod593's Avatar
Yeah just take your 4187 and subtract your passenger capacity( I think our f-bodies are around 700 pass cap) and you should have a ballpark of what you weigh. Give you yourself some room given your differences like fuel quantity, added mods, stereo equipm, etc. I am guessing anywhere from 3400-3500 lbs
Old 01-08-2011, 01:30 PM
FiredUpZ28's Avatar
I never put my LT1 Z on the scales, but my 2000 with a 3800 V6 weighed just shy of 3300 lbs with 3/4 tank without me in it at Byron.
Quick Reply: Camaro Curb Weight?
