Radiator leak (99 SS)
Old 04-12-2011, 02:41 PM
Whisper's Avatar
Default Radiator leak (99 SS)
I had a pretty bad front end accident (to say the least) in my SS about 2 months ago. Got a replacement front bumper, two fenders and a replacement hood (losing SS hood ). After the initial wreck, I saw coolant leaking from under my car, and every time I've added coolant to the car, regardless if its running or not, it leaks out from a weep hole of some sort at the front passenger side bottom part of the radiator. Is there maybe a internal rubber plug that was knocked loose in the wreck causing it to leak from here or is any damage to the plastic tanks on the sides designed to leak from this hole?
Old 04-13-2011, 10:47 AM
Whisper's Avatar
No ideas?
Old 04-19-2011, 03:04 PM
Whisper's Avatar
Got the car back from being painted and it heated up severely. The car leaks slightly from the aforementioned hole while running, but it literally pukes water out of the hole after the car is shut off.
Went to Advanced with my dad to look at a replacement radiator for reference sake- The plug I'm mentioning is at the end of the plastic tank along the side of the radiator, so what exactly is its purpose?
MY dads proposal is to plug the hole with some form of sealant but I cna only imagine what kind of issues this could cause since this is obviously the only release valve or whatever you want to call it the system has. Any kind of information or link to someone with a similar issue would be great before my dad tries the cheap way out and jerryrigs something that's only going to cause a lot more problems.
Old 04-19-2011, 03:09 PM
Whisper's Avatar
On another note, if this car does go to the shop to have the radiator replaces, since the car has air conditioning is there any way of not having to mess with the Ac system as well to remove the radiator?
Old 04-19-2011, 03:29 PM
TheSilverOne's Avatar
taking a pic would help a lot
Old 04-19-2011, 03:49 PM
Whisper's Avatar
Barring removal, theres nothing really I can imagine a picture showing. Its puking water from a plastic drain plug at the bottom of the radiator.
Old 04-19-2011, 07:52 PM
the radiator drain ****?
Old 04-19-2011, 10:36 PM
Whisper's Avatar
If that's what you call the pointed valve pointing towards the ground, and not the actual screw type cap used to release pressure, yes. What kind of damage would cause the radiator to pour water from it or is any damage designed to cause water to pour from that hole?
Old 04-20-2011, 01:43 AM
sjsingle1's Avatar
you can get a replacement drain **** from HELP......otherwise just get a new rad......you dont have to remove the a/c to remove the rad
Old 04-20-2011, 05:45 AM
Clyde H Frasier Jr's Avatar
Drain **** had to have gotten broken from the accident. If it's just slip or broke, get another one.
It might be the radiator also!!!
Quick Reply: Radiator leak (99 SS)
