high pitched screech on startup
when i cold start my car i hear a high pitched screech/squeak and it only last for half a second but its loud kinda sounds like a belt squeaking but im pretty sure its no belt. starter maybe? i have no idea so please share your knowledge with me, thank you.
but right on startup? i would think if it was the power steering pump or a belt it would be making the noise constantly not just for a half a second on cold start please explain.
Belt. Heard it before, many times. Neighbor recently replaced a bad belt that did exactly that. Squealed like hell when started then went away till the car was cold again. If you want to test, take the belts off. Turn the car on for 5-10 seconds, then immediately back off so you aren't running the car with no belts.
Yup, this ^^^ If not, I say make sure it's not one of the check valves for your AIR system. Black check valves that run into the exhaust manifolds from the AIR pump can sound like that when they are faulty or plugged. Not your AC system, but rather the AIR system. Mine sounded like a hissing/screeching sound until I replaced these. I don't know if it's the pump that makes the sound (from surplus pressure resulting from plugged check valves) or the valves themselves. You should get a code pop up for one of your banks (1 or 2) if you do a scan. Let us know if this is the case.
