turn signals & reverse lights dont work
Old 07-07-2011, 10:46 AM
Mightymike2000ss's Avatar
Location: Home town Clive,IA current town FORT BENNING GEORGIA
Default turn signals & reverse lights dont work
I'm in need of some help guys im not sure what happened but my turn signal's or reverse lights wont come on at all the markers light up but not turn signal. the hazards work still. if anyone can give me some input i would appreciate it alot.
Old 07-07-2011, 11:44 AM
98 White T/A's Avatar
Check your fuses before anything.
Old 07-07-2011, 12:40 PM
i thought it was a relay if so which one!!!
Old 07-07-2011, 09:34 PM
Your manual will tell you which fuses are which exactly, im not near my car so i dont have the book next to me to tell you
Old 07-07-2011, 09:54 PM
FiredUpZ28's Avatar
Bet you have a ground issue somewhere if both reverse and turn signals dont work. Rear turn signals im assuming? Best bet is to find a wiring diagram to see what those circuits share.
Old 07-08-2011, 11:02 AM
Save the manuals!
wssix99's Avatar
Is this only in the back or all around?
Old 07-08-2011, 11:15 AM
its all around the car, i got off the interstate one day and i forgot to flip it off and it just stayed on ever since then its never worked.
Old 07-09-2011, 08:49 AM
Save the manuals!
wssix99's Avatar
Best case scenario, you have two separate problems.
If your fuses are good, I'd start by tracing the turn signals. See if you have power at the flasher. If so, it may be a bad flasher. (Your hazards working proves that the DRL module and bulbs/sockets are good.) If no power at the flasher, then you should check the power going in to the turn signal switch and keep going back from there.
Quick Reply: turn signals & reverse lights dont work
