Location-A/C expansion valve 99 Camaro
Old 07-25-2011, 10:40 AM
robertbartsch's Avatar
Default Location-A/C expansion valve 99 Camaro
....where is the A/C expansion value located on a 99 F-body (Camaro)?
Thx.
Old 07-25-2011, 12:26 PM
Do I need an orifice removal tool for the swap?
Old 07-26-2011, 06:46 AM
DAVE00's Avatar
No, just get a pair of pliers and pull it out, as it should come out pretty easily. You deff should have an o-tube (not expansion vavle) and look for the joint between the lines where the high press meets the low after the condensor and that's where your orifice tube will be located.
Old 07-26-2011, 07:11 AM
therealcreeper's Avatar
the orifice tube is in the the smaller bottom line that connects to the firewall, on the firewall side
Old 07-28-2011, 08:56 AM
I removed the small aluminum hose/pipe on the bottom of the evaporator that connects to the condensor near the radiator. I beleive the orifice (expansion valve) is located inside this tube - on the evaporator side (dash board) of the hose; right?
So I can just pull the old orifice (expansion valve) out with a needle nose?
Thanks
I bought a kit - compressor, drier, orifice, oil, o-rings. I will vacumn and hope for a sealed system.
Quick Reply: Location-A/C expansion valve 99 Camaro
