Anyone now ..... which purge valve this is.....
P0443 Evaporative Emission Control System Purge Control Valve Circuit
The one under the hood on the intake
OR
The one in the rear mounted above the axle
I'm stumped. My friends scanner read this code today.............
I've had the smell of gas for almost a year now back by the rear tire and I smell it sometimes when I stop and get out of my car. I guess I'll fix it finally. Just don't know which it is.
OR
The one on the intake is easy to change. I guess I could just go pick one up and try it, see if the code goes away. If not I can return that one. The rear valve is a dealer only item, can't be returned if it doesn't fix it.
Thanks for the PM. Pretty serious procedure......
LS1Tech Administrator
Received 1,794 Likes
Purge valve is the one under the hood, mounted to the intake. GM part number is 1997278.
The valve down by the gas tank/axle is the vent valve.
