Flashing "Service Engine" light after fillup?
OK, I bought the car earlier today, and everything was fine, no lights, except for "check gauges" for gas. I bought it, put 1/4 tank of premium in it and ran most of that out cruising with no issues... I got up for work, filled her up with premium at Shell, and headed out. On the interstate the "service engine soon light" came on, and stayed on for 5 mins or so, flashed for 1-2 mins, then went back solid and stayed on.
My question is, could a loose gas cap cause this? I did a search and couldn't find anything definitive.
I was in a hurry and didn't have time to check it when I got to work, and it's killing me... I'm going to Autozone when I get off to have codes read, but that's in 10 hours, and this is making me sweat BIG time I need
Any help is appreciated.
No off sounds that I heard... Seemed to be running OK. Sorry for posting in the wrong section, BTW.
AAGGGHHH This is driving me nuts, and thanks to 9/11 anniversary I found out that I'm working 12 hour shifts all weekend, so pretty much no spare time...
I REALLY hope that it's the gas cap or something else simple.
Did you top off the tank or stop pumping when the lever clicked off during the fill-up? I don't know if the GM cars are like the trucks, but I over-filled the tank right after I bought a Silverado and got a light the next day. It turned out to be the Evap canister. Fuel from the over-fill made its way down a vent tube and ruined the canister. Wait until you have the code checked and go from there. It was an easy fix for the Silverado, but I will never over-fill a tank in a GM again.
Geez relax...wtf its not the end of the world and for christ sakes its running fine......check the effin cap and be on yer way.....and buy some big boy pants and pull the ******* up! Who the hell puts 1-2 bucks worth of gas in? are you some kinda freak?
that check engine lite knows yer ***** and is ****** with you LMAO
I'm new to the domestic world... I'm used to a flashing MIL equating to something REALLY bad. I've encountered two, and both times before necessitated a complete rebuild. (The first was after I snapped an exhaust cam in half after downshifting into second at 115mph. The second was after leaning out on spray and turning the top of a piston into butter and melting a hole from the exhaust valve relief all the way to the #2 ring land.) Also, I just paid a hair shy of 15 grand for this car and have put less than 30 miles on it. I don't think I'm overreacting.
Will do... Codes should be up in the morning.
Thanks everybody for all the input. I appreciate it... I'll update with codes whenever I get them.
Last edited by roninsonic; 09-08-2011 at 11:03 PM. Reason: text edit (I can't spell. Blame the public skool system.)
It started after you put that first 1/4 tank in there......maybe it has water in it.
The Crank Relearn throws a code....but it doesn't have to be cleared. It has nothing to do with performance of the engine. My SES light has been on for more than a year now because I haven't done the Crank Relearn. We tried like 12 times, it just won't pass......so I said screw it. Engine runs perfect. I might swing by the dealership tomorrow to see if my friend there can get it to take.....Just so my SES light goes out so I will know if I have another issue that pops up...
nah, that 1/4 tank did fine. The light came on after the complete fill up plus the top off. I hope there's no water in the gas... Emptying a full tank would be a PITA and I'd be out 50 bucks.
Somebody mentioned I might have bricked the evap canister... If it's an evap code I'll just block off the evap can, clear it, and ignore it until I can get retuned. Which reminds me, I need to find a tuner in the area...
huh... guess I didn't kill the can, then
Another thing I just thought of... The car was tuned without cats, and the dealer had high-flow cats welded in to pass state inspection. Could this possibly have caused it? I don't know how sensitive the LS1's are to changes in exhaust when it comes to the tune.
Get the codes tomorrow......go from there......
